DAYTON AUDIO SPA-F Mounting Frame for Subwoofer Amplifier SPA250DSP / SPA500DSP
DAYTON AUDIO SPA-F Cadre de Montage pour Subwoofer SPA250DSP / SPA500DSP
The Dayton Audio SPA-F mounting frame allows an SPA250DSP or SPA500DSP subwoofer amplifier to be easily integrated into an existing subwoofer, without cutting out its case. Made from thick, rigid steel, the SPA-F features top and bottom ventilation openings for efficient dissipation of your amplifier.
Reference : 14464
38,90 €tax incl.
32,42 € tax excl.
Dayton Audio SPA-F
Dayton Audio SPA-F Cadre de Montage pour Amplificateur Subwoofer SPA250DSP / SPA500DSP
The Dayton Audio SPA-F mounting frame allows an SPA250DSP or SPA500DSP subwoofer amplifier to be easily integrated into an existing subwoofer, without cutting out its case. Made from thick, rigid steel, the SPA-F features top and bottom ventilation openings for efficient dissipation of your amplifier. Foam gaskets on all contact surfaces help cancel vibrations. With the SPA-F, adding an amplifier to a subwoofer is easier than ever: a screwdriver is all you need.
Product typeMounting frame for subwoofer amplifier
MaterialSteel
CompatibilityDayton Audio SPA250DSP
Dayton Audio SPA500DSP
Dimensions184.1 x 260.3 x 54mm
InputNC
OutputNC
Impedance (Ω)NC
Loudspeaker diameter (mm)N/A
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
ClassN/A
Amplifier chipN/A
Power (W)N/A
The Dayton Audio SPA-F mounting frame allows an SPA250DSP or SPA500DSP subwoofer amplifier to be easily integrated into an existing subwoofer,...
