MONACOR SAM-2 250W Subwoofer amplifier module
The Monacor SAM-2 amplifier is a 250W subwoofer module with excellent design quality and also features a high-pass filter with RCA stereo line level outputs adjustable from 50Hz to 150Hz. An excellent subwoofer module with a wide range of tuning options offering high dynamic capacity with a class A/B amplifier as good at home theater as High fidelity.
By buying this product you get 42 loyalty points
Reference : 1193
429,00 €tax incl.
357,50 € tax excl.
- Subwoofer Monacor SAM-2-
The Monacor Sam-2 Monacor subwoofer module is an amplifier module with screw-in front panel designed by the German manufacturer with a real electronic quality bringing a melodic sound as gifted for Hifi as Home Cinema. The numerous Sub Level and Sub boost settings (from 30Hz to 50Hz) allow a good adaptation to the listening room.
In addition to the low-pass filtering for a dedicated woofer speaker, the Monacor SAM-2 features a high-pass filter on stereo RCA outputs for an amplifier powering amplified speakers or high-pitched midrange satellites adjustable from 50 to 150Hz. This subwoofer also has a grounding or non-earthing button that can avoid grounding or ground loops.
We recommend these speakers for the design of a quality subwoofer with the Monacor SAM 2 module:
DAYTON AUDIO RS225p-4 4Ohm 80W
DAYTON-AUDIO DCS305-4 Subwoofer 4 ohm 250W RMS
DAYTON-AUDIO RS270-8 8ohm 100W
Monacor SPH-10M 200W RMS
Technical specification :
  • Power  : 200 W RMS  4 Ohm, 125W 8 Ohm
  • Line RCA input : 8.4V mono, 4.2V stereo 20kohm
  • High level input binding post :  44V stéreo sur 17K ohm
  • low crossover frequency : (50-150Hz) bande passante 20 Hz-150Hz
  • High crossover frequency : (50-150Hz) bande passante 50Hz-150Hz
  • Signal noise ratio : 70dB
  • DHT Total harmonic distorsion : -0.1%
  • Power supply included : 230V 50hz  300VA
  • Size : 370mm X 185mm X90mm
  • Weight : 4.9Kg
InputSpeaker terminals
ClassClass A / AB
Amplifier chipTransistors
Power (W)250.0
The Monacor SAM-2 amplifier is a 250W subwoofer module with excellent design quality and also features a high-pass filter with RCA stereo line...
