Capacitor 1200V 0.15µF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product type | Capacitor (Super MKP, non-polarized) |
Capacity | 0.15µF |
Voltage | 1200VDC |
Tolerance | ±2% |
Dielectric | Polypropylene foil |
Construction | Dual foil Axial |
Electrode | Aluminum metallized, vacuum deposited |
Wires material | Tinned OFC Copper |
Dielectric absorption factor | < 0.5% @ 20°C |
Dielectric thickness | PB=6µm |
Self-inductance | 0nH |
Insulation resistance | > 100000MΩ @ 20°C |
Temperature range | -55°C to +85°C |
Metal layer thickness | PB=0.4µm |
Metal layer conductivity | PB=2.5Ω/cm² |
Général | |
Dimensions | Ø16 x 43mm |
Poids | 12g |
Tolerance (%) | 2 |
Capacitor capacitance (µF) | 0.15 |
Rated voltage (V) | 1200 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
