JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 1μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 6589
11,90 €tax incl.
9,92 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio Superior Z-Cap
Capacitor 800V 1µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity1µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ18 x 43mm
Poids16g
Tolerance (%)2.0
Capacitor capacitance1
Rated voltage (V)800.0
Capacitor typeFilm capacitor
Capacitor formatAxial
4 reviews
Great capacitors , very neutral, balanced with great detailes
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 1μF
mr
Colissimo is a terrible courier. 17 days and nothing. Dhl never ever any problems. Always deliverde quickly to Austrtalia
Tout simplement le meilleur rapport qualité-prix que je connaisse.
Le rendu à un petit quelque chose d'analogique...
Parfait l’extrême aiguë
Ce condensateur offre un filtrage très fin et délicat tout simplement musical.
Il exprime l’extrême aiguë sans acidité, agressivité. Je recommande vivement.
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
