JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 3.3μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 6594
18,90 €tax incl.
15,75 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio Superior Z-Cap
Capacitor 800V 3.3µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity3.3µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ30 x 45mm
Poids40g
Tolerance (%)2.0
Capacitor capacitance3.3
Rated voltage (V)800.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
Excellents en tout point.
J'ai refait les filtres de mes Cabasse Caravelle M2 (9 condensateurs et 7 selfs puis une résistance) entièrement avec cette série de condensateurs.
Tout simplement parfaits.
Les dimensions surtout du condensateur 6.8 µF sont impressionnantes, j'ai dû utiliser une plaque de contre-plaqué sur les 2 faces dans mes enceintes.
Ne pas utiliser cependant cette série Z-Cap superior sur haut-parleurs isodynamiques ou à ruban, préférez les Mundorf Suprême Classic dans ce cas.
Livraison Audiophonics toujours aussi rapide, bravo !!
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 3.3μF
Filtration.
Il est parfait.
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
