JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 6.8μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 6598
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio Superior Z-Cap
Capacitor 800V 6.8µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity6.8µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ35 x 65mm
Poids76g
Tolerance (%)2.0
Capacitor capacitance6.8
Rated voltage (V)800.0
Capacitor typeFilm capacitor
Capacitor formatAxial
4 reviews
Impressionnant déjà par les dimensions...
Ce condensateur est énorme, bien vérifier s'il rentre dans votre filtre.
Mis en série à la suite du même en 3.3 µF pour mon aigu Cabasse Dom 4/4.
J'ai utilisé une plaque de contre-plaqué sur les 2 faces tant les condensateurs Z-Cap Superior et les selfs Jantzen sont surdimensionnés.
Médium Cabasse Dom 12 avec 2 condensateurs identiques en 2.2 µF montés en parallèle pour obtenir les 4.4 µF requis en série sur mes Cabasse Caravelle M2.
Le son est extrêmement transparent, superbement timbré et jamais agressif, avec le rodage (300 heures au moins pour un condensateur) ça promet !!
A noter que cette série de condensateurs Jantzen Z-Cap superior ne convient pas du tout sur les hauts-parleurs isodynamiques ou à ruban, une catastrophe sur médium-aigu AMT Ess à l'unanimité de l'assemblée d'audiophiles... leur préférer dans ce cas les Mundorf Suprême Classic.
Audiophonics toujours au top de la livraison, commandés le vendredi et reçus le lundi, on ne peut pas faire mieux.
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 6.8μF
Very good
Used them on my Dali zensor 7 crossover. definetly an audible improvement !
Ottimo
Ottimo servizio e prezzo. Montato su B&W CDM 7SE fantastico
Parfaite dans le signal du tweeter.
C'est ma préférée dans le signal du tweeter.
Très bon rapport qualité prix.
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
