JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 8.2μF
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every detail of the signal, while maintaining unparalleled naturalness and realism.
Reference : 6599
35,90 €tax incl.
29,92 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio Superior Z-Cap
Capacitor 800V 8.2µF
Jantzen Audio Superior Z-Cap Condensateur
In particular, they are recommended for use as a capacitor for high-end tweeters or as a coupling capacitor in an amplifier. All Jantzen Audio Z-Cap capacitors have a nitrogen filling that allows the amount of foil per capacitor to be increased while eliminating the risk of evaporation that can be found in capacitors using oil or other dielectric fluids.
Superior Z-Cap capacitors are not polarized. The signal can therefore pass in both directions, without impacting the reproduction or sound performance.
Product typeCapacitor (Super MKP, non-polarized)
Capacity8.2µF
Voltage800VDC
Tolerance±2%
DielectricPolypropylene foil
ConstructionDual foil
Axial
ElectrodeAluminum metallized, vacuum deposited
Wires materialTinned OFC Copper
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thicknessPB=6µm
Self-inductance0nH
Insulation resistance> 100000MΩ @ 20°C
Temperature range-55°C to +85°C
Metal layer thicknessPB=0.4µm
Metal layer conductivityPB=2.5Ω/cm²
DimensionsØ35 x 70mm
Poids77g
Tolerance (%)2.0
Capacitor capacitance8.2
Rated voltage (V)800.0
Capacitor typeFilm capacitor
Capacitor formatAxial
5 reviews
Condensateur Jantzen audio superior Z-cap
Condensateur de qualité utilisé sur un filtre d'ordre 2 pour des tweeters Heil AMT.
Je recommande.
This review has been posted for JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 8.2μF
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 8.2µF
Excellent condensateur(associé au 800v 4.7 µF) pour la réfection d'un filtre passif 2 voies sur enceintes BW DM5 après changement de tweeter ( Dayton DC 28 FT-8), et recâblage interne (Neotech multibrin). Très bonne bande passante, aigus fins et détaillés , graves tendus et parfaitement maitrisés ,belle musicalité.
Très bon condensateurs, j'ai modifié mes DAVIS EVA 5 au niveau du filtre de mes tweeters. Puis après avoir entendus le rendus, j'ai modifié le filtre de mon médium avec ses condensateurs.
Un rendus très juste .
Pour finir , suppressions des mes mundorf suprême de mon ampli. avoir !!
frédéric.
Excellents condensateurs, même une petite préférence par rapport aux Mundorf suprême, avec beaucoup de détails dans les hautes fréquences sans être trop analytique et timbre très juste très bon rapport qualité prix. éric..
frédéric.
éric
Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system...
