LB Aluminum Push Button with Blue Light 220V Ø12mm Silver
1NO type switch with blue indicator light. Operates from a bistable mechanism (two positions). The connectors dedicated to the signal / power supply can support a voltage of 220V. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 5 and 24V.
Reference : 17518
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 24-04-2025.
Switch
1NO 220V
LB Interrupteur Aluminium avec Cercle Lumineux Bleu 5-24V Ø12mm Argent
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Product type1NO Bistable switch
Screw thread diameter12mm
Max panel thickness8mm
Total dimensions26.3*⌀13.8mm
LEDColor: Blue
Voltage: 5-24V
Number of pins4
Voltage220V
LED ColorBlue
Number of positions2
Button type1NO
1NO type switch with blue indicator light. Operates from a bistable mechanism (two positions).  The connectors dedicated to the signal /...
