LB Bistable Aluminium Button with White Light 250V Ø16mm Black
1NO1NC type button with white indicator light. Operates from a bistable mechanism.
Reference : 17167
6,50 €tax incl.
5,42 € tax excl.
Bistable Button
1NO1NC 250V
LB Interrupteur Aluminium avec Cercle Lumineux Blanc 9-24V Ø16mm Noir
1NO1NC type button with white indicator light. Operates from a bistable mechanism (2 positions).
The connectors dedicated to the signal / power supply are gold plated and can support a voltage of 250V / 3A. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 9 and 24V.
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Characteristics
Product typeBistable button 1NO1NC
Screw thread diameter16mm
Max panel thickness12mm
Total dimensions35*⌀21 mm
LEDColor: White
Voltage: 9-24V
Number of pins5
Voltage / Current250VAC / 3A
Mechanical life800000 cycles
Reference life40.000 hours
Operating temperature-30°C, +80°C
Insulation>= 1000mΩ
Dielectric strength1000VAC min
LED Color
  • White
Number of positions
  • 1
Button type
  • 1NO1NC
