LB Bistable Aluminium Switch with White Light 250V Ø19mm Black
1NONC type switch with white indicator light. Operates from a bistable mechanism (two possible positions).
Reference : 15295
6,90 €tax incl.
5,75 € tax excl.
Shipping date: 29-04-2025.
BISTABLE Switch
1 pole 2 positions 1NONC 250V
LB Interrupteur Aluminium avec Cercle Lumineux Blanc 9-24V Ø19mm Noir
The connectors dedicated to the signal / power supply are gold plated and can support a voltage of 250V / 3A. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 9 and 24V.
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Characteristics
Product typePush button 2 positions 1NONC
Screw thread diameter19 mm
Max panel thickness13 mm
Total dimensions28 mm x ⌀22 mm
Button diodeWhite LED
Voltage 9-24V
Number of pins5
Voltage / Current250VAC / 3A
Mechanical life800000 cycles
Reference life40.000 hours
Operating temperature-30°C, +80°C
Insulation>= 1000mΩ
Dielectric strength1000VAC min
LED ColorWhite
Number of positions2
Button type1NO1NC
