Aluminium Stands 39x18mm Black (Set x4)
The sturdy aluminum feet reduce vibrations and limit the transmission of vibrations to other parts. One spike can support up to 8kg. With a set of 4 you can support up to 32kg.
Reference : 17741
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 24-04-2025.
aluminium stands
Pieds aluminium 39x18mm Noir (Set x4)
These stands for speakers and Hi-Fi equipment have the particularity of eliminating a common problem: damaged surfaces. These spikes allow you to move your equipment without scratching the floor.
When the weight of your Hi-Fi elements is concentrated on a small surface, the pressure per cm² increases considerably providing a better contact with its support. The result is an improved soundstage through better control of the bass register.
These feet allow for better sound reproduction, reduced distortion and better low frequency control. These feet with spikes are recommended for the isolation of active subwoofers, speakers or any other Hi-Fi equipment that needs to be elevated.
Technical caracteristics
Product typeStands
MaterialAluminium
Weight capacity / stands8kg
Adjustable min/max height18mm / 23mm
Diameter of the support surface 25mm
Total diameter39mm
Dimensions39*18mm
Weight47g
ColorNoir
PackageSet x4
Diameter (mm)39.0
MaterialAluminium
Height18.0
Excellents pieds
Matériel qui respire la qualité je conseille
This review has been posted for Aluminium Stands 39x18mm Black (Set x4)
The sturdy aluminum feet reduce vibrations and limit the transmission of vibrations to other parts.  One spike can support up to 8kg....
