LHY AUDIO Main AC EMI Noise Tester 300kHz - 700kHz
This mains noise tester allows to measure the interference and therefore the noise on a power network and to compare filtered and unfiltered systems. It operates over a frequency range of 300kHz to 700kHz. Below or above these values, an LED lights up to indicate that the value is out of range.
Reference : 15637
109,90 €tax incl.
91,58 € tax excl.
Shipping date: 22-04-2025.
LHY AUDIO Noise Tester
Testeur de bruit secteur EMI AC 300kHz - 700kHz
Using it to compare an unfiltered and a filtered system is simple: just plug the tester into the unfiltered system, set the sensitivity to 100, and then plug the tester into the filtered system to see the difference in noise.
A loudspeaker at the device makes the noise audible. The higher the noise level, the higher the sound level.
Product typeNoise tester
Input voltage220-240VAC (IEC C7 power cable not included)
Measuring frequency range300kHz - 700kHz
Dimensions91 x 134 x 48mm
This mains noise tester allows to measure the interference and therefore the noise on a power network and to compare filtered and unfiltered...
