Professionnal cable tester battery-powered
Reference : 14362
69,90 €tax incl.
58,25 € tax excl.
repair tool diagnostic test cables
Cable tester battery powered
This cable tester is equipped with a large variety of connectors which allow you to check that the current is flowing properly while confirming that no short-circuits have found their way in.
Through a rotary switch, this cable checker can test independently each conductor of the cable.
It works with XLR, RCA, 3.5mm / 6.35 TRS, banana plugs, Speakon, RJ45 and DIN connectors (complete list below).
For all types of non-supported connectors, the tester comes with a pair of test cables provided to manually access the less conventional connectors. An audible indicator then takes over the visual LED indicator.
TypeCable tester
ConnectorsSpeakon 8-pole female x2
Speakon 4-pin x2
Jack TRS 6.35mm female x2
Jack TRS 3.5 mm female x2
RCA x2 female
DIN 3-8 pole female x2
5 pole female XLR x 1
XLR 5-pole male x 1
XLR 3-pin female connector x 1
XLR 3 pole male x 1
RJ45 female CAT 5 x 2
Banana Plug female x 2
Power supply9V battery (supplied)
Dimensions190 x 113 x 36 mm
Weight1.05 kg
Package contents
Cables test on banana plugx2
9V batteryx1
Cable testerx1
InputRJ45
InputJack 3.5mm
InputXLR
InputJack 6.35mm
