ELECTRO HARMONIX 6CA7EH Tetrode Amplification Tubes (Matched Quad)
The Electro Harmonix 6CA7 amplifier tubes are classic tetrodes in Big Bottle format. They are designed to adapt to amplifiers with high gain while providing precision and sound richness to restore the integrity of the original audio signal.
4.7 / 5
Reference : 13811
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 23-04-2025.
3 >Month warranty
Electro Harmonix 6CA7EH
Electro Harmonix 6CA7 Tubes d'Amplification (Set x4 Appairés)
The Electro Harmonix 6CA7 amplifier tubes are classic tetrodes in Big Bottle format. They are designed to adapt to amplifiers with high gain while providing precision and sound richness to restore the integrity of the original audio signal. Their design allows them to saturate less quickly than many other tubes, thus preserving beautiful sound clarity, even at high volume. 6CA7 tubes are also compatible with EL34 models, for example for replacement.
Matched quad
These Electro Harmonix 6CA7 tubes are delivered by 4 and are matched by the brand. This process allows to obtain almost identical values for each tube in order to improve its performance. Ideal for perfect assembly.
Product typeTubes
MatchedYes, quad
Heater voltageMin. 5.7V
Max. 7V
Heater current (@ heater voltage = 6.3V)1.5A +/-0.1
Max cathode current150mA
Cathode / Heater voltage+/-300V
Max plate voltage800V
Plate current100mA +/-20 *
Max plate dissipation25W
Max grid 1 negative voltage100V
Max grid 1 circuit resistnaceFixed bias : 0.5MΩ
Automatic bias: 0.7Ω
Max grid 2 voltage425V
Grid 2 current<= 20mA *
Max grid 2 dissipation8W
Transconductance10mA/V *
Output power>= 9W **
Non linear harmonic distorsion coefficient<= 13.5% **
Dimensions110mm x Ø38mm
* Uh = 6.3V; Up = 250V; Ug2 = 250V; Ug1 = -13.5V
* Uh = 6.3V; Up = 250V; Ug2 = 250V; Ug1 = -13.5V; Ug1 alt.eff = 9.6V; R load = 2kΩ
Contacts numberN/A
Tube typeTetrode
6 reviews
swift delivery
I received my ordered items so fast even christmas season. So I can enjoy my time with the parts for amplifier. I thank you, Audiophonics!
This review has been posted for ELECTRO HARMONIX 6CA7EH Tetrode Amplification Tubes (Matched Quad)
Tube rolling
J'ai commandé un quartet de 6CA7 Electro Harmonix pour un ampli Line Magnetic LM211IA, ce dernier avait encore ses tubes de puissance EL34 d'origine(Shuguang rebadgés Line Magnetic) qui fonctionnaient très bien avec une belle sonorité.
J'avais commencé par changé les tubes de préamplification 12au7 et 12ax7 d'origine par des Psvane 12au7S et 12ax7S, le bon qualitatif avait été énorme....!
Avec les 6CA7 l'ampli a conservé son fruité et son coté délié, détaillé et profond avec en plus le coté impact...! Et la sonorité riche du Live...!
Ces tubes de puissance comme tous tubes neufs doivent être montés, réglage du bias, laisser chauffer à vide volume à zéro environ 30mn.... vérifier le bias, réglage si nécéssaire et écouté.... Vérification plusieurs fois du bias(au bout d'une heure avec ajustage très très léger), puis le réglage ne bouge plus du tout.
Ne pas s'inquiéter, au bout d'une demie heure ça avait un peu bougé... C'est un rodage....
J'ai même eu une toute toute petite sifflante sur une voie qui a disparu après la première heure.... Rodage.. rodage, je ne sais pas si c'est pour tout le monde pareil mais pour moi ça c'est passé comme ça.....
Après 5 heures d'écoute(en 2 fois) le résultat est franchement à la hauteur, il y a sans aucun doute sûrement mieux mais ce ne sera plus le même budget et pour quelle différence ?
Sinon merci encore à Audiophonics pour son sérieux et sa rapidité même en période de Noël pour satisfaire les commandes, produits conformes et emballage au top comme d'habitude, Bravo...!
Comme d’habitude excellent
Ça fait quelques années que je command du matériel sur audiophonics et à chaque fois j’apprécie la vitesse d’expédition et la qualité des produits
Top !!!
Belle tenue générale mais trop de retenue ?
J'ai depuis 4 mois un ampli Line Magnetic LM211ia, équipé de lampes Shuguang : 4 EL34, 2 ECC82 et 2 ECC83 (d'ailleurs en vente sur ce site). Polarisation des EL34 réglable et 2 modes d'écoute possibles : triode et ultralinéaire (mon préféré).
Récemment, mon incorrigible audiophilie m'a fait acheter un jeu complet d'Electro Harmonix, dont ces 6CA7EH. Leur appairage m'a semblé correct à 90 % d'après le réglage permis par mon ampli.
Après environ 70 heures d'écoute, je trouve ces tubes droits, précis, "raisonnables", comparés au petit grain de folie généreuse, même si un peu brouillonne et moins propre auquel les EL34 Shuguang m'avaient habitué. Les 6CA7EH offrent un son plus détaillé et moins chaud que les Shuguang, un grave mieux tenu et cerné, l'aigu aussi, même s'il me semble plus court que les EL34 d'origine.
Donc, je ne pense pas qu'un rodage plus avancé apportera cette ouverture qui me manque. Ou peut-être que mon ampli est plus conçu pour des EL34, ce qui n'enlève rien à ces 6CA7EH. Impression finale mitigée, entre belle maîtrise sonore des Electro Harmonix, et ce supplément de vie des EL34 Shuguang.
6ca7 HELECTRO HARMONIX
En remplacement de KT88 sur mon TAC 34, dont je pense qu'ils n'étaient pas prévus pour cet amplificateur, et bien je redécouvre mon amplificateur. Il revit. Son détaillé, chaud sans être trop lourd, tout le spectre est bien restitué et équilibré.
Je redécouvre mes cd et surtout le plaisir d'écoute en Hi-ress via Qobuz.
NB:Système secondaire composé de l'amplificateur TAC 34, enceintes B&W 601 S1, lecteur CD TEAC CD-H750, un Google Chromecast audio et dac SMSL Sanskrit 10TH.
The Electro Harmonix 6CA7 amplifier tubes are classic tetrodes in Big Bottle format. They are designed to adapt to amplifiers with high gain while...
