GENALEX GOLD LION Tube 12AT7 / ECC81 / B739 Gold Pins (Unit)
The high-end Genalex Gold Lion Gold Pins double triode tube unveils a wide sound stage, characterized by expressive midrange, deep and precise bass and generously developed treble.
Reference : 14527
49,90 €tax incl.
41,58 € tax excl.
3 >Month warranty
Genalex Gold Lion
Genalex Gold Lion Tube 12AT7 / ECC81 / B739 Gold Pins
The high-end Genalex Gold Lion Gold Pins double triode tube unveils a wide sound stage, characterized by expressive midrange, deep and precise bass and generously developed treble. This re-release of the Genalex Gold Lion ECC81 / B739 faithfully recreates the sound signature of the original, considered the best 12AT7 tube ever designed.
The contacts of this tube are gold plated, allowing a very good conductivity and resistance to oxidation.
Product typeCustom tube
Compatibility12AT7
ECC81
B739
Grid reverse currentNot more than 0.5µA @ Heater voltage = 6.3V or 12.6V, Plate voltage = 250V, Grid voltage = -2V, Grid circuit resistance = 0.25M Ohm
Heater currentNot less than 330mA @ Plate voltage = 6.3V
Not less than 165mA @ Heater voltage = 12.6V
Not more than 360mA @ Plate voltage = 6.3V
Not more than 180mA @ Heater voltage = 12.6V
Current plateNot less than 7mA @ Heater voltage = 6.3V or 12.6V, Plate voltage = 250V, Grid voltage = -2V
Not more than 13mA @ Heater voltage = 6.3V or 12.6V, Plate voltage = 250V, Grid voltage = -2V
Plate current at the beginning of the curveNot more than 10µA @ Heater voltage = 6.3V or 12.6V, Plate voltage = 250V, Grid voltage = -12V
TransconductanceNot less than 4.5mA/V @ Heater voltage = 6.3V or 12.6V, Plate voltage = 250V, Grid voltage = -2V
Amplification factorNot less than 50 @ Heater voltage = 6.3V or 12.6V, Plate voltage = 250V, Grid voltage = -2V
Limit values
Heater voltageNot less than 6V or 12V
Not more than 6.6V or 13.2V
Plate voltageNot more than 330V
Cathode to heater voltagePositive : Not more than 200V
Negative : Not more than 200V
Plate currentNot more than 18mA
Plate dissipation power of each triodeNot more than 3.25W
Each triode grid circuit resistanceFixed bias : Not more than 0.25M Ohm
Automatic bias : Not more than 1M Ohm
Max grid reverse currentNot more than 55V
Interelectrode capacitances
Input capacitance of each triode2.5pF
Output capacitance of each triode0.4pF
Transfer capacitance of each triode1.6pF
Contacts number
  • N/A
Tube type
  • Dual Triode
3 reviews
GENALEX GOLD LION Tube 12AT7 / ECC81 / B739 Gold Pins (Unité)
Changement des deux lampes JJ électronique de mon ampli advance paris A 10 par deux GENALEX GOLD LION CC81,des lampes de très bonnes qualités,un son doux , profond,et très détaillé,des basses très agréables,des lampes de préampli audio excellentes!!!
This review has been posted for GENALEX GOLD LION Tube 12AT7 / ECC81 / B739 Gold Pins (Unit)
Parfait
Acheté pour remplacer les Telefunken de mon DAC Scala. Je ne sais pas si c'est parce que ces derniers étaient usés ou parce que c'était leur signature, mais les Genalex ont eu un effet spectaculaire. Tout se raffermit, tout s'agrandit. J'ai également été surpris en bien, alors que je lisais qu'ils étaient euphoniques, de les trouver plutôt neutres (ou alors, c'est que j'appelle une coloration de la neutralité, mais je ne pense pas :). Rien d'exagéré, pas d'effet de loupe. Si vous cherchez ce que l'on appelle à tort du "son tube", passez votre chemin. Si vous cherchez un bon tube, allez-y.
Belle amélioration
Il remplace avantageusement une EH qui équipait mon ampli casque Canor tp10: aigu plus suave, médium plus souple et champ sonore mieux ressenti avec mon Grado PS500E.
The high-end Genalex Gold Lion Gold Pins double triode tube unveils a wide sound stage, characterized by expressive midrange, deep and precise bass...
