JJ ELECTRONICS ECC802S / 12AU7 GOLD Tubes (Matched Pair)
The ECC802S / 12AU7 from JJ Electronics is a dual triode preamplifier tube. This hi-fi quality tube is perfect for replacing a 6189, 12AU7WA, E82CC or CV4003 tube or for integration into a DIY audiophile project.
Reference : 19487
105,00 €tax incl.
87,50 € tax excl.
3 >Month warranty
JJ ELECTRONICS ECC802S / 12AU7 GOLD Tube Dual Triode Preamplifier Tube (Matched Pair)
JJ ELECTRONICS ECC802S / 12AU7 : Front view
The ECC802S / 12AU7 GOLD from JJ Electronics is a dual triode preamplifier tube. This hi-fi quality tube is perfect for replacing a 6189, 12AU7WA, E82CC or CV4003 tube or for integration into a DIY audiophile project.
JJ ELECTRONICS ECC802S / 12AU7 : Technical data
Product typePreamp tube
Tube typeDual triode tube
Compatibility6189, 12AU7WA, E82CC, CV4003
Pole numbers9
Caractéristiques types
Filament heating voltage (Uf)6,3/12,6 V
Filament heating current (If)300/150 mA
Anode operating voltages (Ua)250 V
Cathode resistor (Rk)800 Ω
Plate current (Ia)10,5 mA
Mutual conductance (S)2,2 mA/V
Control grid impedance (Ri)7,7 kΩ
Amplification power (µ)17
VALEURS MAX.
Anode operating voltages (Ua)330 V
Anode dissipation (Wa)3 W
Cathode current (Ik)22 mA
Grid control voltage (Ug)- 55 V
External resistor control grid (Rg)1 MΩ
Cathode voltage (Uk)100 V
CAPACITANCES
Capacitance between control grid and cathode (Cg/k)1,6 pF
Capacitance between anodes (Ca)0.5 pF
Capacitance between control grid and anode (Cg/a)1.5 pF
DimensionsØ22.2 x 57.6mm
PackageSold by pair
Contacts number9
Tube typeDual Triode
JJ ELECTRONICS ECC802S / 12AU7 GOLD Dual Triode Preamplifier Tubes (Matched Pair)
The ECC802S / 12AU7 from JJ Electronics is a dual triode preamplifier tube. This hi-fi quality tube is perfect for replacing a 6189, 12AU7WA, E82CC...
