PSVANE 211-TII HiFI Tubes Triode (Matched Pair)
The PSVane 211-TII tube is a high quality direct heated thorium-tungsten triode that can be used in class A, B and C. The MKII series tubes use a PTFE base, ensuring high stability and very good insulation. The amber colored oxidized aluminum collar surrounding the PTFE base prevents corrosion and fingerprints while giving the tube a prestigious design.
By buying this product you get 28 loyalty points
Reference : 17015
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
PSvane 211-TII
HiFi Tubes Triode (Matched Pair)
PSvane 211-TII Tubes HiFi Triode (Paire Appairée)
The PSVane 211-TII tube is a high quality direct heated thorium-tungsten triode that can be used in class A, B and C. The MKII series tubes use a PTFE base, ensuring high stability and very good insulation. The amber colored oxidized aluminum collar surrounding the PTFE base prevents corrosion and fingerprints while giving the tube a prestigious design. The tube also uses a high quality glass for increased durability. On the sound side, this model reveals a beautiful clarity and sound image.
The 211-TII is sold here as a matched pair (two tubes), thus maximizing its performance.
Product typeTubes
Tube typeTriode
Number of pins4
Heater
Uf10V
If3.25A
Static parameters
Ua1250V
Ug70V
Ia100mA
Gm3.8mA/V
µ (Ia=75mA)12
RL7k
Output10W
Direct interelectrode capacitances
Input6pF
Output5.5pF
Grid to plate14.5pF
Contacts number4
Tube typeTriode
Excellents tubes
Testés depuis maintenant 3 semaines sur des blocs ATM211. Un peu froid au départ, maintenant vraiment très biens, fluides et détaillés!! Reste plus qu'à voir sur la durée ....
This review has been posted for PSVANE 211-TII HiFI Tubes Triode (Matched Pair)
The PSVane 211-TII tube is a high quality direct heated thorium-tungsten triode that can be used in class A, B and C. The MKII series tubes use a...
