PSVANE WE101D-L REPLICA HiFi Tubes (Matched Pair)
These Psvane WE101D-L tubes are perfect replicas of Western Electric's 101D, now extremely rare and expensive, with pines similar to those of the 300B. These are tubes of exceptional quality, offering absolutely exceptional precision and linearity.
By buying this product you get 64 loyalty points
Reference : 12864
649,00 €tax incl.
540,83 € tax excl.
3 >Month warranty
High End Hi-Fi Matched Tubes (Pair)
A bit of history
101D tubes were first designed by Western Electric in the early 20th century. It is a triode tube with direct heating, like the 300B but with a lower output and extremely precise low voltage amplification allowing excellent fidelity and linearity on all frequencies. At the time used in telecommunications, Western Electric never authorized the use of 101Ds by any other company. Thus, they have become extremely difficult to find today and the few remaining units display very high prices.
Top-of-the-range matched tubes
Because these tubes are of absolutely exceptional quality, offering precision and perfect fidelity, Psvane has created the WE101D-L Replica. This will allow 101D amplifier owners to enjoy the full potential of their system, without having to pay thousands of euros. This is the WE101D-L model, with pins of different sizes and thicknesses, similar to the 300B. Moreover, these Psvane tubes are perfectly matched to offer identical restitution on each channel.
A few things to check before changing your 101D tubes
  • Filament voltage and current: The filament voltage of the WE101D-L is 4.5V and its amperage is 1A. Check these settings to prevent damage to your device.
  • The tubes socket: Check that your tubes to be replaced correspond to the diagram below, with pins of different sizes and thicknesses. If the pins are the same length and short, they may be WE101D tubes.
Typical operating parameterHeater voltage : 4.5V
Heater current : 1A
Ua : 190V
Ia : 6.4mA
Ug : -18V
Min / Max parametersHeater voltage : Min 4V / Max 5V
Ua : Max 300V
Ia : 30mA
Pa : 15W
Direct interelectrode capcitancesInput : 4.8 uuF
Output : 5.2 uuF
Grid to Plate : <= 3.3 uuF
Recommended burn-in time80 - 150 hours
MaterialsAluminium base
Gold plated pins
Max diameter60mm
Total height120mm
Without pins height105mm
Contacts number
  • 4
Tube type
  • Triode
These Psvane WE101D-L tubes are perfect replicas of Western Electric's 101D, now extremely rare and expensive, with pines similar to those of...
