SOVTEK 12AX7WA / 7025 Twin Triode Tube (Unit)
This Sovtek 12AX7WA/7025 double triode tube with low gain and extremely low microphony is ideal for the replacement of a 12AX7/ECC83 tube, or in a DIY setup. This model is known for its musicality and the roundness of its reproduction.
Reference : 16027
18,90 €tax incl.
15,75 € tax excl.
Shipping date: 16-04-2025.
3 >Month warranty
Sovtek 12AX7WA / 7025
Twin Triode Tube
Sovtek 12AW7WA / 7025 Tube Double Triode
Sovtek 12AW7WA / 7025 Tube Double Triode Sovtek 12AW7WA / 7025 Tube Double Triode
Product typeTube
Tube typeTwin triode
Number of pins9
DimensionsØ22.5 x 56.5mm
Electrical parameters
ParameterConditionsMinMax
Heater currentFilament voltage : 6.3V300mA340mA
Filament voltage : 12.6V150mA170mA
Grid reverse currentFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V, grid circuit resistance 1MΩ-0.2µA
Plate currentFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V0.75mA2mA
First and second triodes plate current differenceFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V-±40%
Amplification factorFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V82110
Limit values
Filament voltageParallel connection6V6.6V
Series connection12V13.2V
Plate voltage--300V
Cathode - Heater votlage--±200V
Cathode current--10mA
Power dissipation at the plate of each triode--1W
Grid circuit resistance for each of the triodesFixed bias-1MΩ
Self bias-2.2MΩ
Contacts number9
Tube typeDual Triode
3 reviews
Order Detail N°479896 - 2024-10-28
Je les ai reçus le 11/04/2024 17.20
Merci.
This review has been posted for SOVTEK 12AX7WA / 7025 Twin Triode Tube (Unit)
DESCRIPTIF CONFORME
Belle scene sonore, belles définition, belle musicalité, bref dans la lignée de qualité d’écoute de ce fabricant et comme toujours à prix imbattable. Privilégié au Genalex Gold Lion qui est déjà une très belle référence. Installé sur mon préamplificateur Aesthetix, les tubes livrés fonctionnent parfaitement (4éme série de tube commandée chez Audiophonics et parfait fonctionnement pas comme chez TAD). Appairage pas nécessaire pour un préamplificateur, la balance est respectée. Donc sans hésitation.
Conforme
Conforme à mes attentes. Livraison rapide et colis bien protégé. Super !
This Sovtek 12AX7WA/7025 double triode tube with low gain and extremely low microphony is ideal for the replacement of a 12AX7/ECC83 tube, or in a...
