Je les ai reçus le 11/04/2024 17.20
Merci.
Twin Triode Tube
This Sovtek 12AX7WA/7025 double triode tube with low gain and extremely low microphony is ideal for the replacement of a 12AX7/ECC83 tube, or in a DIY setup. This model is known for its musicality and the roundness of its reproduction.
Product type | Tube |
Tube type | Twin triode |
Number of pins | 9 |
Dimensions | Ø22.5 x 56.5mm |
Electrical parameters | |||
Parameter | Conditions | Min | Max |
Heater current | Filament voltage : 6.3V | 300mA | 340mA |
Filament voltage : 12.6V | 150mA | 170mA | |
Grid reverse current | Filament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V, grid circuit resistance 1MΩ | - | 0.2µA |
Plate current | Filament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V | 0.75mA | 2mA |
First and second triodes plate current difference | Filament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V | - | ±40% |
Amplification factor | Filament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 2V | 82 | 110 |
Limit values | |||
Filament voltage | Parallel connection | 6V | 6.6V |
Series connection | 12V | 13.2V | |
Plate voltage | - | - | 300V |
Cathode - Heater votlage | - | - | ±200V |
Cathode current | - | - | 10mA |
Power dissipation at the plate of each triode | - | - | 1W |
Grid circuit resistance for each of the triodes | Fixed bias | - | 1MΩ |
Self bias | - | 2.2MΩ |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Nikos Z.
Christophe M.
