SOVTEK 5881WXT Power Beam Tube Tetrode (Unit)
The Sovtek 5881WXT is an extremely fialbe tetrode type power tube. Built to rigid military standards, the 5881WXT tolerates higher voltages than most other types of 6L6 tubes. It is frequently used to replace defective 7027 tubes.
Reference : 16029
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
Sovtek 5881WXT
Sovtek 5881WXT Tube de puissance tétrode
Sovtek 5881WXT Tube de puissance tétrode Sovtek 5881WXT Tube de puissance tétrode
Product typeTube
Tube typeTetrode
Number of pins6
DimensionsØ38 x 110mm
Electrical parameters
ParameterConditionsMinMax
First grid reverse currentFilament voltage 6.3V, plate voltage 250V, grid voltage #2 250V, grid circuit resistance #1 0.51M-0.7µA
Heater current-0.84A0.92A
Plate currentFilament voltage 6.3V, plate voltage 250V, grid voltage #2 250V60mA88mA
Second grid currentFilament voltage 6.3V, plate voltage 250V, grid voltage #2 250V-6mA
Output powerFilament voltage 6.3V, plate voltage 250V, grid voltage #2 250V, plate circuit resistance 2.5k5.8W-
Limit values
ParameterMinMax
Filament voltage6V6.6V
Cathode - heater voltage-±250V
Cathode current-90mA
Frist grid voltage, negative-100V
Power dissipation at the plate-20.5W
Power dissipation at the second grid-2W
First grid circuit resistance-0.51MΩ
Contacts number6
Tube typeTetrode
The Sovtek 5881WXT is an extremely fialbe tetrode type power tube. Built to rigid military standards, the 5881WXT tolerates higher voltages than...
