TUNG-SOL 12AU7 / ECC82 Tubes (Matched Pair)
The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open restitution certainly audiophile, but will also work very well for the design of an amplifier guitar, this one supporting very well the distortion.
4.5 / 5
Reference : 16246
43,90 €tax incl.
36,58 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
TUNG-SOL 12AU7/ECC82
Military quality tube (Matched Pair)
Tung-Sol 12AU7/ECC82 tubes de qualité militaire (la paire)
The Sung-Tol brand has long been known for the high quality of its tubes but also for their incredible timbre. Manufacturing quality that lasts, even on these new models. Thus, Tung-Sol tubes reflect the best of the brand's vintage manufacturing, with unmatched sound and reliability.
Techincal characteristics
Direct interlectrode capactitances
Triode 1With shield *Without shieldUnit
Grid to plate1.51.5pf
Input1.81.6pf
Triode 2With shieldWithout shieldUnit
Input1.81.6pf
Output2.00.32pf
* External shield #315 connected to cathode of unit under test
Données de chaque triode
Class A AmplifierVertical deflection amplifierUnit
Maximum heater-cathode voltage (negative)200200Volts
Maximum heater-cathode voltage (positive)200200Volts
Max plate voltage300300Volts
Max peak positive plate voltage---1200Volts
Max plate dissipation for each plate2.752.75Watts
Max plate dissipation for both plate5.55.5Watts
Max peak negative grid voltage---250Volts
Max cathode current2020mA
Max peak cathode current---60mA
Max grid circuit resistance : Fixed Bias0.25---MegaOhm
Max grid circuit resistance Cathode Bias12.2MegaOhm
Ratings of each triode unit
Vertical deflection oscillatorHorizontal deflection oscillatorUnit
Maximum DC plate voltage300300Volts
Max dissipation for each plate2.752.75Watts
Max dissipation for both plate5.55.5Watts
Max peak negative grid voltage400600Volts
Max average cathode current2020mA
Max peak cathode current60300mA
Max grid circuit resistance2.22.2MegaOhm
Caractéristiques et conditions d'utilisation classiques
Amplificateur Class AChaque TriodeUnité
Tension de la plaque100250Volts
Tension de la grille0-8.5Volts
Courant de la plaque11.810.5mA
Résistance de la plaque (approx)65007700Ohm
Transconductance31002200µOhm
Facteur d'amplification2017
Contacts number9
Tube typeN/A
2 reviews
Paire de TUNG-SOL 12AU7/ECC82
Je viens de les monter dans mon préampli ART PRO MPA II, en remplacement des lampes chinoises d'origine.
A première écoute ces Tung-Sol sonnent très clair et aéré, avec une très bonne linéarité sur l'ensemble du spectre et d'une grande précision.
En revanche, je trouve qu'elles manquent un peu de coloration et de chaleur lors de la prise de voix, mais comme je viens de les monter, peut-être manquent-elles de rodage ou de préchauffage ? A voir avec le temps..
This review has been posted for TUNG-SOL 12AU7 / ECC82 Tubes (Matched Pair)
COPPIA SELEZIONATA ECC82
Splendida coppia selezinata, motata su un TotemPole, sono risultate praticamente perfette.
The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This...
