TUNG-SOL 12AU7 / ECC82 Tubes (Unit)
The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This one proposes an open restitution certainly audiophile, but will also work very well for the design of an amplifier guitar, this one supporting very well the distortion.
Reference : 13075
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 13-05-2025.
3 >Month warranty
TUNG-SOL 12AU7/ECC82
Military quality tube (Unit)
Tung-Sol 12AU7/ECC82 tubes de qualité militaire (la paire)
The Sung-Tol brand has long been known for the high quality of its tubes but also for their incredible timbre. Manufacturing quality that lasts, even on these new models. Thus, Tung-Sol tubes reflect the best of the brand's vintage manufacturing, with unmatched sound and reliability.
Techincal characteristics
Direct interlectrode capactitances
Triode 1With shield *Without shieldUnit
Grid to plate1.51.5pf
Input1.81.6pf
Triode 2With shieldWithout shieldUnit
Input1.81.6pf
Output2.00.32pf
* External shield #315 connected to cathode of unit under test
Données de chaque triode
Class A AmplifierVertical deflection amplifierUnit
Maximum heater-cathode voltage (negative)200200Volts
Maximum heater-cathode voltage (positive)200200Volts
Max plate voltage300300Volts
Max peak positive plate voltage---1200Volts
Max plate dissipation for each plate2.752.75Watts
Max plate dissipation for both plate5.55.5Watts
Max peak negative grid voltage---250Volts
Max cathode current2020mA
Max peak cathode current---60mA
Max grid circuit resistance : Fixed Bias0.25---MegaOhm
Max grid circuit resistance Cathode Bias12.2MegaOhm
Ratings of each triode unit
Vertical deflection oscillatorHorizontal deflection oscillatorUnit
Maximum DC plate voltage300300Volts
Max dissipation for each plate2.752.75Watts
Max dissipation for both plate5.55.5Watts
Max peak negative grid voltage400600Volts
Max average cathode current2020mA
Max peak cathode current60300mA
Max grid circuit resistance2.22.2MegaOhm
Caractéristiques et conditions d'utilisation classiques
Amplificateur Class AChaque TriodeUnité
Tension de la plaque100250Volts
Tension de la grille0-8.5Volts
Courant de la plaque11.810.5mA
Résistance de la plaque (approx)65007700Ohm
Transconductance31002200µOhm
Facteur d'amplification2017
Contacts number
  • 9
Tube type
  • N/A
7 reviews
gain appréciable
Acheté pour changer le tube chinois de l'ampli Xduoo mt 605, belle et appréciable différence : aération, clarté, douceur des aigus, de la musique, quoi !
This review has been posted for TUNG-SOL 12AU7 / ECC82 Tubes (Unit)
Very good
I put this new tube in my Xduuo 605 amp and the sound is fantastic... very good. It's an huge upgrade from the original tube at a very nice price!
leonasj
very musical tubes,separate instrumens,3D sound ,low noise,nice vocals,linear gain. way far better vs im tried TAD,telefunken,rft tubes. immediatly loved them after change my xduoo ta-22 stock tubes( also very good linear sound,but tungsol goes further)
tung sol 12au7
Excellent ! pas de bruit, même à niveau élevé, son parfaitement modulable en jouant sur le gain.
lampe préampli
reçu très rapidement pour upgrader un préampli à lampe, avec une gamme militaire de très bonne qualité
The Tung-Sol 12AU7, manufactured in Russia, ensures very low noise. It has been designed to mimic the performance of American NOS 6189 tubes. This...
