TUNG-SOL 7189 Pentode Power Tube EL84 / 6BQ5 (Unit)
The Tung-Sol 7189 pentode tube has been developed for applications in amplifier output stages of high-fidelity amplifiers. Due to its characteristics, it is interchangeable with EL84 and 6BQ5 tubes.
Reference : 14230
37,90 €tax incl.
31,58 € tax excl.
Shipping date: 24-04-2025.
3 >Month warranty
Tung-Sol 7189
Tube de puissance pentode haute qualité (EL84 / 6BQ5)
Tung-Sol 7189 Tube de puissance pentode haute qualité (EL84 / 6BQ5)
The Tung-Sol 7189 pentode tube has been developed for applications in amplifier output stages of high-fidelity amplifiers. Due to its characteristics, it is interchangeable with EL84 and 6BQ5 tubes. However, it differs from the latter by offering a higher maximum plate voltage and power as well as a higher nominal screen voltage. Its robust design for extended life and improved performance make this 7189 tube an excellent solution to replace or improve a tube amplifier.
Production of the original 7189 tubes ended in the early 1980s and they became expensive and difficult to find. Tung-Sol has therefore launched the production of new 7189 tubes with the same technical specifications and performance as the original models.
Product typePower tube
Type of tubePentode
Heater voltage6.3V
Heater current760mA
Direct Interelectrode capacitances
Input capacitance10.8pF
Output capacitance6.5pF
Plate to Grid #10.5pF
Grid #1 to Heater0.25pF
Contacts number9
Tube typePentode
The Tung-Sol 7189 pentode tube has been developed for applications in amplifier output stages of high-fidelity amplifiers. Due to its...
