TUNG-SOL 7189 Pentode Power Tubes EL84 / 6BQ5 (Matched Pair)
The Tung-Sol 7189 pentode tube has been developed for applications in amplifier output stages of high-fidelity amplifiers. Due to its characteristics, it is interchangeable with EL84 and 6BQ5 tubes.
Reference : 17588
72,90 €tax incl.
60,75 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
Tung-Sol 7189
High Quality Pentode Power Tube (EL84 / 6BQ5) (Matched Pair)
TUNG-SOL 7189 Tube de Puissance Pentode Haute Qualité (EL84 / 6BQ5) (Paire Appairée)
The Tung-Sol 7189 pentode tube has been developed for applications in amplifier output stages of high-fidelity amplifiers. Due to its characteristics, it is interchangeable with EL84 and 6BQ5 tubes. However, it differs from the latter by offering a higher maximum plate voltage and power as well as a higher nominal screen voltage. Its robust design for extended life and improved performance make this 7189 tube an excellent solution to replace or improve a tube amplifier.
Production of the original 7189 tubes ended in the early 1980s and they became expensive and difficult to find. Tung-Sol has therefore launched the production of new 7189 tubes with the same technical specifications and performance as the original models.
The Tung-Sol 7189 is sold here by 2 units paired together, allowing to optimize the performances.
Tung-Sol 7189 Tube de puissance pentode haute qualité (EL84 / 6BQ5)
Product typePower tube
Type of tubePentode
Heater voltage6.3V
Heater current760mA
Direct Interelectrode capacitances
Input capacitance10.8pF
Output capacitance6.5pF
Plate to Grid #10.5pF
Grid #1 to Heater0.25pF
Contacts number9
Tube typePentode
The Tung-Sol 7189 pentode tube has been developed for applications in amplifier output stages of high-fidelity amplifiers. Due to its...
