TUNG-SOL KT120 Power Tubes (Matched Pair)
The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver between 150 and 200W.
Reference : 13074
135,00 €tax incl.
112,50 € tax excl.
Shipping date: 22-04-2025.
3 >Month warranty
TUNG-SOL KT120
Power tubes high quality (Matched pair)
TUNG-SOL KT120 Tubes de Puissance Haute Qualité (Paire Appairée)
The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver between 150 and 200W. When used with existing 6550 / KT88 / KT90 circuit parameters, the KT120 becomes overload proof, delivering peak power with extreme reliability and very long life. Moreover, by taking advantage of the ability of these tubes to handle high currents, it is quite possible to design a unique, powerful and stable amplifier.
The Sung-Tol brand has long been known for the high quality of its tubes but also for their incredible timbre. Manufacturing quality that lasts, even on these new models. Thus, Tung-Sol tubes reflect the best of the brand's vintage manufacturing, with unmatched sound and reliability.
These tubes are delivered in pairs and are matched by the brand in order to obtain the closest values and therefore the best possible operation. Ideal for perfect assembly.
Tung-Sol KT120 Tubes de puissance haute qualité (paire Appairée)
Direct interelectrode capacitances (Without shield)
Input29pf
Output10pf
Grid 1 to plate1.8pf
Heater characteristics and ratings
Average characteristics6.3V 1.7-1.95A
Maximum voltage heater of negative cathode300V
Maximum voltage heater of positive cathode200V
Maximum ratings
Plate DC VoltageTetrode : 850V
Triode 650V
Grid 2 DC VoltagePentode connection : 650V
Triode and ultra-linear connection : 600V
Grid 1 DC Voltage-200V
Plate dissipation60W
Grid 2 dissipation8W
Cathode currentPentode connection : 250mA
Triode and ultra-linear connection : 30mA
Grid 1 circuit resistanceFixed Bias : 51000 Ohm
Self Bias : 240000 Ohm
Bulb temperature250°C
Plate voltage400V
Grid 2 voltage225V
Grid 1 voltage-14V
Plate current (range)165 - 165mA
Grid 2 currentNot more than 14mA
TransconductanceNot less than 12.2mA/V
Plate resistanceApprox 3000 Ohm
Max signal power outputNot less than 20W
Total Harmonic DistorsionNot more than 14%
Cathode to heater leakage (with +-300V heater to cathode difference)Not more than 30uA
Contacts number7
Tube typeN/A
2 reviews
KT120 Tung Sol
Bonjour à toutes et à tous.
Ayant débuté en 1967, il y a 55 ans, j'ai construit notamment il y a quelques années un canal basses pour multi-amplification autour des tubes KT90 EH. Le remplacement par des KT120 n'apporte pas une augmentation de puissance, mais procure des basses mieux tenueset dynamiques qu'avec des KT90 EH voire des 6550 Sylvania ou Tung-Sol NOS ni des KT88 GEC. Ce tube est un excellent choix dans les basses grace à une plaque bien dimensionnée et surtout une cathode mieux chauffée que celles des KT90, KT150 ou KT170, lesquelles travaillent à plus basse température de cathode.
Par contre leur rendu en large bande laisse à désirer par rapport aux tubes NOS et même aux KT150.
VAGNER Michel, Moselle.
This review has been posted for TUNG-SOL KT120 Power Tubes (Matched Pair)
KT120
Bonjour,
On a toujours une petite appréhension lorsqu'on essaie de nouveau tubes surtout lorsqu'ils coutent cher(enfin c'est cher pour mon budget).
J'avais un lots de transfos Chrétien, comme ceux de sorties encaissent 100W, j'ai tenté de les associer aux KT120. Le résultat à largement dépassé mes espérances. Le tube KT120 associe une forte puissance, une grande dynamique et une magnifique richesse de timbre avec notamment un aigu fin et soyeux. Les transfos de sortie on certainement une grande part dans le résultat finale néanmoins je conseille l'achat de ces tubes. Mes premiers essais on été fait avec des 6550 EH et des KT88 Gold Lyon, la KT120 a apporté plus de puissance sans rien sacrifier aux timbres, bien au contraire.
Raphaël.
 (3)
The Tung-Sol KT120 has a 60W dissipation tray, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull...
