Thanks to its expertise in the production of customized audio / video cables, the ELECAUDIO team has devised a modulation cable capable of upsetting the established order as it implements materials and technologies usually reserved for products at prices very high, or inaccessible.
This cablee modulation ELECAUDIO SC-401 in Litz asymmetric wire is intended for lovers of High fidelity wanting to evolve the connection of their helmets or their HIFI installations.
hewill be an excellent cable for the DIY design of audiophile modulation cables.
Flexible and robust at the same time, this cable is composed of 4 braided conductors made of PE copper PE insulated. The Litz wire structure with an insulating varnish on the 48 strands is recognized by audiophiles as offering a musical sound, accurate with timbre.
The special braiding of this cable allows real isolation without the use of a metal sheath or strip that can raise the capacitive load and prove harmful in harmonics.
The conductors are composed of 48 strands in Litz wire structure of 0.06 mm each in 4 PE insulators. A part with Kevlar strands ensures mechanical maintenance for a better hold over time.
Transpa colorsrents and blacks will greatly facilitate the identification during the welding step.
We recommend the RCA plugs with copper body for a good audio result.
Features:/ Strong>
- 4 conductors OFC copper
- Kevlar internal braiding wires
- PE insulation
- Structure: 4 x 48 strands of 0.06mm in Litz wire structure (4xAWG26, 4x0.14mm²)
- Cable Diameter: 3.8 x 1.36mm
- Sold by the meter
