MOGAMI 2368 Unbalanced interconnect cable mic 0,08mm² Ø2mm
Reference : 10920
0,80 €tax incl.
0,67 € tax excl.
MOGAMI cables are the perfect example of the brand's expertise and manufacturing quality, including these asymmetrical cables that maintain the necessary mechanical strength (tensile strength and long life) and flexibility for a cable microphone / headphone.
Cable sold by the meter.
Driver Features:
  • Details: 16 / 0,08 A <T1000D * 1>
  • Section (mm²): 0.08mm² (28 AWG)
  • Insulation Diameter: Ø 1mm (0.039 ")
  • Insulation Material: PVC
  • Insulation Color: white
Cable Features:
  • Diameter: Ø 2mm (0.079 ")
  • Materials: soft PVC
  • Black color
Electrical and mechanical characteristics:
  • Resistance at 20 ° C: 0.10Ω / m (0.031Ω / Ft)
  • Insulation resistance:   100000 MQ × m Min. to DC 125V, 20 ° C
  • Tensile Strength: 206N
  • Temperature range: -20 ° to + 70 ° C
Diameter (mm)2.0
Length (m)Sold by length
Number of conductors1
Insulation materialPVC
ShieldingNo
Section (mm²)0.08
Ground / ShieldingYes
3 reviews
Souple, facile à souder, suffisament résistant
J'utilise régulièrement ce câble pour assembler des micros à capsules électret. Étant relativement souple, il est assez peu microphonique, à condition de réaliser un bon découplage mécanique du câble juste avant la capsule.
This review has been posted for MOGAMI 2368 Unbalanced interconnect cable mic 0,08mm² Ø2mm
Great Cable
Used this cable for DIY microphones. It's easy to solder, flexible, and very stable, while having a small diameter.
Great Cable for DIY Projects !
This is a great cable for DIY projects with space restrictions. The cable is lightweight, flexible, and easy to solder !
