SOMMERCABLE ONYX TYNEE HIGHFLEX Unbalanced cable Ø 4mm
Reference : 9580
0,90 €tax incl.
0,75 € tax excl.
Shipping date: 29-04-2025.
Câble vendu au mètre
SOMMERCABLE ONYX TYNEE HIGHFLEX Câble Asymétrique Ø4mm
The twin...
is similar to the TRICONE MKII type because of its design and quality, but the twinned conductors reduce the clutter of the cladding. Its use is recommended for the production of hi-fi cables, adapters, and for fixed wiring. It is compatible with most jack and cinch connectors.
The SC-ONYX cable is made up of separable conductors. Each has an individual helical copper shield and is equipped with thick insulation, color coded: white and red or respectively white and yellow (SC-ONYX 2008).
By his dithe SC-ONYX 2008 type is predestined for use with mini-jack connectors. It is delivered without marking. Also available as single conductor (diode cable): SC-ONYX-TYNEE.
ADVANTAGES :
  • High flexibility due to thin strands
  • Each conductor separately insulated and shielded by helical copper winding
  • The conductors can be easily separated by hand
  • Outer sleeve of reduced diameter, advantageous for the mounting of the connectors jack or cinch
USE :
  • Wiring for asymmetric devices (keyboards)
  • Connections for hi-fi equipment
  • Manufacture of Y adapters
  • Manufacture of cables insert
Specifications:
ConstitutionLI2YDY2x0,22mm2
Envelope, outside diameterPVC 4,0 mm
AWG24
Conductor inside1 x 0.22 mm2
Copper strands per core7 x 0.20 mm
Insulation of the conductorPE
Protectionhelical screen by copper wire
Optical cover95%
Operating temperaturemin. -20 ° C
Temperatureof usemax. 70 ° C
Fire resistance per m0.12 kWh
Weight per m18 g
Packaging, packaging unitper meter
Colorblack
Electrical Specifications :
Metric Capacity Screen / Display125 pF
Odometer Resistance, Conductor<85 Ohm
Resistance, insulation> 1 GOhm
Diameter (mm)4.0
Length (m)Sold by length
Number of conductors1
Insulation materialOther
ShieldingYes
Section (mm²)0.22
Ground / ShieldingYes
