SOMMERCABLE STRATOS Modulation cable Asymmetric 1x0,34 mm² Ø8.5mm
4.4 / 5
Reference : 782
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 23-04-2025.
https://www.audiophonics.fr/images2/783/Stratos_anthrazit.gif
SOMMER CABLE - Stratos
Honesty is the safest guarantee ...
This becomes evident when, after a few years of service, some hi-fi cables are put under the microscope. Even very expensive phono cables are in a desolate state: porous sheath, contracted insulation, oxidized copper. The conductors are undoubtedly subjected to extreme conditions when the "boiling" transformerst extreme heat or aggressive gases. In a short time the materials are damaged, and the devaluation of the technical and electrical characteristics is programmed.
What does not happen with the STRATOS: it is not only electrically but also acoustically appropriate to the characteristics of high-end hi-fi systems. The sounds transmitted by STRATOS are distinguished by their unrivaled naturalness, fullness, lightness, discretion and absolute silence during musical breaks. Shielded with a multiple screen (braid + semiconductor), the STRATOS is perfectly protected against the problematic electromagnetic disturbances. The protective tubular braid is combined with special plastic fibers to facilitate thermal clearance, and the heat-resistant sheath ensures extreme durability. For a better conductivity, the copper cores undergo a special surface treatment. The insulation is ensured by a mixture of PE / PP with microscopic structure particularized by its durability. The STRATOS is ideal for connections between CD player / recorder DAT / DVD / preamplifier and terminal amplifier.
ADVANTAGES:
  • Lively and very natural sound
  • Multiple protection against parasitic fields BF and HF
  • Long life, durability of electrical characteristics
  • Adaptable without dito different hi-fi components
USE:
  • Phono cable for extreme requirements
Technical characteristics:
Constitution(LIHS09YHS1x0,34mm 2) DY
Envelope, diameterPVC 8.5 mm
AWG22
Conductor1 x 0.34 mm 2
Copper strands per core7 x 0.25 mm
Conductor insulationeurPE / PP
Protectionscreen by copper braid + semiconductor
Optical cover100%
Operating temperaturemin. -20 ° C
Operating temperaturemax. 80 ° C
Fire resistance per m0.25 kWh
Weight per m55 g
Packaging, packaging unitto the metere
Coloranthracite
Electrical Specifications:
Metric Capacity Screen / Display75 pF
Odometer Resistance, Conductor<53 Ohm
Resistance, insulation> 1 GOhm
Diameter (mm)8.5
Length (m)Sold by length
Number of conductors1
Insulation materialOther
ShieldingYes
Section (mm²)0.34
Ground / ShieldingYes
18 reviews
Très bon mais pas neutre
bande passante très équilibrée, léger voile dans les aigus provenant d'une petite coloration, légère mais néanmoins identifiable sur un système qui privilégie une restitution naturelle.
This review has been posted for SOMMERCABLE STRATOS Modulation cable Asymmetric 1x0,34 mm² Ø8.5mm
EXCELLENT TOUT SIMPLEMENT...
Enfin un câble qui n'est pas ceci ou cela mais qui se fait oublier, tout simplement. Pas de plus beau compliment pour un maillon HIFI. Attention à choisir des connecteurs de qualité type Tellurium plaqué or par exemple sans quoi vous risquez de passer à coté de cet excellent câble.
Bien
rendu naturel, sans agressivité, associé aux fiches viablue t6s.Celles-ci paraissent plus définies que les rca neutrick nf2cb2 montées sur le stratos aussi.
LIVE !
Ce qui caractérise ce câble c'est la dynamique.
Habitué des prise de sons, je retrouve cette précision du son live où ""on entend tout"...
Je redécouvre mes enregistrements presque comme en MASTER.
Aucun registre n'est mis en avant. Les timbres sont fabuleux
C'est fou toutes les parties du message sonore qui sont masqués par les autres cables.
Très beau grave et c'est très lumineux.
Au montage la tresse verte est pas simple à travailler ; mais ça va quand même !
J'ai utilisé des fiches WBT qui traînaient dans un coin de mon stock avec une soudure argent sur l'âme
Stratos pour phono
C'est le deuxième montage liaison platine phono que je réalise avec ce câble. Silencieux, parfait du moins dans cette configuration de montage où il redonne un peu de chaleur à certains vinyles qui pourraient en manquer.
