VIABLUE NF-B Subwoofer LFE Modulation Cable Ø7.5mm
4.8 / 5
Reference : 101
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 23-04-2025.
this cable is sold by the meter
Viablue cable woofer NF-B
Cable ViaBlue sold by meter
RCA cables for subwoofer NF-B designed for powerful and precise bass signal.
The electrical capacitance between the inner conductor and the conductive screen has been increased thanks to the use of large diameter inner conductor.
A thermoplastic material, the low density polyethylene (LDPE) is used as an insulator, further increasing the electric capacity while maintaining the same dimensions and flexibility.
Capacity per meter of this type of cable can thus reach 128 pF / m.
RCA NF-B cables were developed specifically for connecting subwoofers to your amplifier
The signal transmission focusing on the bass range is maintained at its maximum so that the intensity is not lost over long distances.
The bass boxes can thus find the best location according to the acoustics of the space needed.
TypeSpeaker cable
LengthTailored
In increments of 1m
Insulatinglow density polyethylene (LDPE)
Drivercopper strands formed OFC
section driver5.06mm²
armouringTriple
external diameter7.5mm
Diameter (mm)7.5
Length (m)Sold by length
Number of conductors1
Insulation materialOther
ShieldingYes
Section (mm²)5.00
Ground / ShieldingYes
9 reviews
Attention fiches RCA gros diamètre.
Attention, utilisez impérativement des fiches RCA adaptées à du gros câble, il fait 7.5mm de diamètre, l'âme centrale environ 3mm, et la masse, une fois regroupée, au moins 4mm. Utilisez de préférence les fiches à visser de cette même marque. Le câble semble néanmoins de bonne facture, à utiliser de préférences pour les grandes longueurs, aussi, il n'est pas très flexible.
This review has been posted for VIABLUE NF-B Subwoofer LFE Modulation Cable Ø7.5mm
Excellent !
It is was used in my home cinema and pluged in a subwoofer Velodyne.
It enhances the sound ,with low costs .
Excellent
Excellent
J'ai acheté ce cable pour remplacer un modèle de chez oelbach, quelle différence, grave plus tendu plus ferme, exceptionnel, je recommande.
J'y ai mis des fiches rca viablue t6s.
valeur sure
2e fois que j’achète ce produit suite à une nouvelle configuration (besoin d'un câble plus long)
Ce câble est vraiment efficace sur le registre grave, et est finalement pas si cher au vu de sa qualité.
Qui veut des basses ? De bonnes basses ?
Pas facile à manipuler pour souder sur RCA, mais la peine en vaut le plaisir d'écoute. Des basses ça s'écoute (orgue par exemple). Le rendu est très réaliste. Je l'utilise sur un caisson de monitoring et le rendu est magnifique. Gaine souple au final.
Recommander !
 (3)
