Adaptateur OTG Micro USB female to USB-C male
Reference : 12707
2,50 €tax incl.
2,08 € tax excl.
Shipping date: 29-04-2025.
Micro-USB adapter USB-C
USB Adapter c
This adapter Micro USB female to male USB-C allows you to connect to your devices using the USB-C connector.
It is equipped with the standard OTG (On The Go) which does not need a master machine (computer). It is therefore possible to use it as a direct connection without needing a master machine such as a computer (provided both devices are OTG compliants)
Suitable for audio use on recent devices, this adapter is a good solution to connect to your DACs and recent interfaces like the Boss Allo DAC v1.2. This will use this adapter to connect directly to a smartphone or any device capable of storing and OTG-compatible digital audio.
TypeAdapter
InputMicro USB
OutputUSB-C
OTG standardYes
Dimensions24 x 9.8 x 5 mm
ConnecticMale & Female
ConnectorUSB-C
ConnectorMicro USB
Compacte, efficace
Adaptateur très compact. Fonctionne parfaitement depuis plus d'un an.
This review has been posted for Adaptateur OTG Micro USB female to USB-C male
This adapter works perfectly with  ALLO BOSS DAC PCM5122 32Bit / 384kHz with 2 clocks Master Clock I2S
