DD TC35B Male USB-C to Female Jack 3.5mm DAC Adapter CTIA 32bit 384kHz
This TC35B adapter consists of a 3.5mm jack female connector on one side and a USB-C male connector on the other side. It will allow you to connect a 3.5mm jack to a device with a USB-C connection only, as it is the case on many recent smartphones.
Reference : 14426
36,90 €tax incl.
30,75 € tax excl.
This product has been replaced by the new version, the DD TC35B 2021 Adapter DAC USB-C.
TC35B
TC35B Adaptateur DAC USB-C Mâle vers Jack 3.5mm Femelle CTIA 32bit 384kHz
This TC35B adapter consists of a 3.5mm jack female connector on one side and a USB-C male connector on the other side. It will allow you to connect a 3.5mm jack to a device with a USB-C connection only, as it is the case on many recent smartphones. The components are integrated in a compact and robust 316 stainless steel housing. The TC35B automatically detects and activates when a headset is connected. The adapter is also CTIA compatible and can therefore be used with headsets/earphones with integrated controls and microphone.
Volume control for Apple headphones is not supported.
Product typeJack 3.5mm / USB-C adapter
ConnectorsFemale Jack 3.5mm
Male USB-C
USB CodecALC5686
THD+N< -92dB
DNR> 110dB
SNR> 120dB
Output power30mW @ 32Ω
Recommended headphone impedance16-200Ω
CTIA Support
Housing materialStainless Steel 316
Dimensions18.8 x 11.2 x 10.2mm
Weight6g
ColorSilver
This TC35B adapter consists of a 3.5mm jack female connector on one side and a USB-C male connector on the other side. It will allow you to connect...
