SATA III to USB 2.0 Adaptater Cable Blue 0.20m
Reference : 12065
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 16-04-2025.
SATA male adapter to USB-A 2.0 Male 20cm
SATA to USB external hard disk drive internal
This SATA III adapter cable to USB 2.0-A male is ideal for your devices that do not have a SATA plug for hard drive or external SSD 2.5 "or 3.5" up to 4TB. A significant expansion memory to store your music library just on devices like a Raspberry Pi or Sparky SBC Sexample.
Extremely easy to use, it offers compatibility with most operating systems (Windows, Mac OS, Linux, Android) and will connect even on your compatible smartphone OTG (adapter not included Micro USB necessary). When using a 3.5 "hard drive it will suffice to add a DC power supply 12V 2A 3.6 / 1.3mm (not supplied).
The cable takes advantage of a quality design, with copper conductors to enhance conductivity and shielding to minimize interference. The connectors are in turn protected by a cover for protection against impacts, dust and water and the USB connector with a Gold plating. Finally, the cable PVC sheath ensures durability and flexibility.
Warning: To use a hard disk 3.5 "or drive / CD / DVD / Bluray it is necessary to use a non supplied 12V 2A (see references above accessories).
Length20cm
ConnectorsUSB 2.0-A male / male SATA III
gold plated
cable conductor materialCopper
Cable conductor section 28AWG
sheath materialPVC
CompatibilityWindows, Mac OS, Android, Linux
Hard Disk Max 4tb
Shell shock protection, dust, waterYes
Power supplyJack DC 12V / 2A (size 3.5 / 1.3mm)
color connectors Blue
cable color Grey
Accessoriesx4 feet
ConnecticMale
ConnectorSATA
