AUDIOPHONICS DIGITAL AUDIO Male USB-A to Male USB-B Cable 4N OFC Copper PTFE 0.5m
The Audiophonics Digital Audio USB cable is a digital cable developed by the Audiophonics team and assembled in our workshops. The objective is to obtain a high level USB cable, without the usual defects of current productions in this price range.
Reference : 14089
34,90 €tax incl.
29,08 € tax excl.
Audiophonics Digital Audio Câble USB-A Mâle vers USB-B Mâle Cuivre OFC 4N PTFE 0.5m
This cable is the combination of USB connectors with gold plated contacts, an OFC Copper cable of 4N (99.99%) purity with PTFE insulation. This cable is completely assembled in our workshops with a Silver / Sn95 Mundorf M-Solder soldering on a constant temperature soldering iron.
This cable has a separate shield, isolating the data transmission from the 5V electrical voltage part. A second shielding covers the whole system to guarantee 100% protection against parasites.
Unlike a conventional USB cable with only an external shield, vil is an elegant and logical solution, reducing unwanted noise between digital data transmission and 5V voltage.
This cable is not suitable for acquisition applications (microphone, ADC, etc.).
Product typeUSB Cable
Length0.5m
Connectors1x Male USB-A
1x Male USB-B
Connectors platingGold
Connectors isolant materialPVC
Cable isolant materialPTFE
DATA / 5V Voltage separation
ShieldingAluminium foil 100%
Conductors material4N OFC Copper
Conductors number4
External sheath materialPVC
Covering sheath materialNylon
Cable colorWhite and gray
Cable diameterØ9mm
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorUSB-A
ConnectorUSB-B
Découverte de l'importance de la qualité du câble USB à l'écoute.
Avant que de commander ce câble USB Audiphonics, j'ai lu pas mal d'avis sur l'efficacité de câbles de bonne qualité sur le son. En fait j'étais perplexe et le suis resté jusqu'à ce que je remplace le câble USB d'origine de mon combo DAC/AMP Audio GD NFB 1138 Performance. le plaisir Audiophile pourrait être décrit en comparant une boisson acide au citron avec la même dans laquelle on aurait ajouté du miel et du rum. Depuis j'attends que le câble secteur Pangéa AC14 SE MK2 soit à nouveau en stock chez Audiophonics et je change celui d'origine sans hésitation. Bravo Audiophonics, cohérence de la qualité sonore audiophile dans tous les éléments de la chaîne sonore.
This review has been posted for AUDIOPHONICS DIGITAL AUDIO Male USB-A to Male USB-B Cable 4N OFC Copper PTFE 0.5m
The Audiophonics Digital Audio USB cable is a digital cable developed by the Audiophonics team and assembled in our workshops. The objective is to...
