AUDIOPHONICS DIGITAL AUDIO Male USB-A to Male USB-B Cable 4N OFC Copper PTFE 1m
The Audiophonics Digital Audio USB cable is a digital cable developed by the Audiophonics team and assembled in our workshops. The objective is to obtain a high level USB cable, without the usual defects of current productions in this price range.
Reference : 11075
39,90 €tax incl.
33,25 € tax excl.
Audiophonics Digital Audio Câble USB-A Mâle vers USB-B Mâle Cuivre OFC 4N PTFE 0.5m
This cable is the combination of USB connectors with gold plated contacts, an OFC Copper cable of 4N (99.99%) purity with PTFE insulation. This cable is completely assembled in our workshops with a Silver / Sn95 Mundorf M-Solder soldering on a constant temperature soldering iron.
This cable has a separate shield, isolating the data transmission from the 5V electrical voltage part. A second shielding covers the whole system to guarantee 100% protection against parasites.
Unlike a conventional USB cable with only an external shield, vil is an elegant and logical solution, reducing unwanted noise between digital data transmission and 5V voltage.
This cable is not suitable for acquisition applications (microphone, ADC, etc.).
Product typeUSB Cable
Length1m
Connectors1x Male USB-A
1x Male USB-B
Connectors platingGold
Connectors isolant materialPVC
Cable isolant materialPTFE
DATA / 5V Voltage separation
ShieldingAluminium foil 100%
Conductors material4N OFC Copper
Conductors number4
External sheath materialPVC
Covering sheath materialNylon
Cable colorWhite and gray
Cable diameterØ9mm
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorUSB-A
ConnectorUSB-B
13 reviews
Ce câble fonctionnait mieux dans mon environnement qu'un câble qui coutait beaucoup plus cher. Par contre, ce dernier câble était meilleur dans d'autres environnements. Comme quoi tout est une question de mariage. Au niveau des qualités de l'AUDIOPHONIC, j'ai noté de la précision après un période de rodage dépassant une dizaine d'heures et une belle ouverture. C'est un câble a tendance neutre.
This review has been posted for AUDIOPHONICS DIGITAL AUDIO Male USB-A to Male USB-B Cable 4N OFC Copper PTFE 1m
câble USB
Utilisé entre un PC et un ampli-dac casque FX-AUDIO, il me donne entière satisfaction. Bel emballage et impression de qualité et de solidité. Rien à redire
Excellent rapport Q/P
Étant très satisfait du câble ethernet AUDIOPHONICS, j'ai commandé ce câble USB en remplacement d'une référence moyen de gamme mais réputé pour ses qualités audio.
Le câble AUDIOPHONICS va bien plus loin : Scène sonore plus large, plus profonde, plus de détails, le haut du spectre se révèle sans pour autant négliger le reste.
Attention, pendant les premières heures d'écoute (dureté et crispation dans le haut du spectre), comme tous les bons câbles, celui ci nécessite un rodage de plusieurs heures (30h mini).
Idéalement 3 jours à une semaine.
Perso je le rode avec du DSD pour accélérer le processus.
Le câble respire la qualité, attention tout de même au rayon de courbure qui peut être pénalisant.
Je l'ai placé entre un Jitterbug et un ifi Audio USB IPURIFIER.
Impressionnant !!
Fonctionne mieux que mon WireWorld Ultraviolet 7 que j'avais avant...
A part dans l’extrême grave.
Etonnant !
A croire que ce câble passe des zéros plus ronds et des uns plus droits !
Echange à chaud pendant l'écoute d'Ahmad Jamal à l'Olympia.
Le bas médium s'est tellement enrichi que je prévois une nouvelle mesure et une correction de mes atténuateurs !
Le son du piano est enfin boisé comme il doit l'être,c'est la description la plus simple que je peux donner.
Belle création Audiophonics, complément indispensable de l'interface digitale Audiophonics.
( Compressions Radian 475PB sur pavillon Musique Concrète/LeCléach,Supravox 285GMF charge Jensen,interface digitale Audiophonics,filtrage DCX2496 "Jan Didden",2x Atoll AM200 )
The Audiophonics Digital Audio USB cable is a digital cable developed by the Audiophonics team and assembled in our workshops. The objective is to...
