AUDIOPHONICS PULSAR Male USB-A to Male USB-B Cable Silver / Gold Plated 0.75m
The Audiophonics Pulsar USB cable, thanks to a precise and meticulous design, using high-end materials, ensures a stable and clean signal transmission for high quality sound reproduction.
4.3 / 5
Reference : 14812
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 27-12-2024.
Audiophonics Pulsar
Audiophonics Pulsar Câble USB-A Mâle vers USB-B Mâle Plaqué Argent / Or 1m
The Pulsar integrates a cable whose conductors are made of Copper OFC 4N with silver plating, ensuring maximum electrical conductivity. These conductors are individually insulated by a PTFE sheath. A double shielding composed of a copper braid and an aluminium foil guarantees a high immunity to parasitic noise. The cotton filling provides excellent mechanical strength and damping.
Another specificity of this cable is that the DATA and 5V voltage wires are separated by a shield, in order to limit considerably the interferences between conductors. Finally, we cover the cable with a beautiful and effective Nylon braided sheath, which also contributes to the resistance of the cable to mechanical stress.
The connectors used are Viborg UA201 for USB-A and Viborg UB201 for USB-B. The latter, particularly robust, benefit from contacts made of a copper alloy with 24k gold plating, promoting both conductivity and oxidation resistance for maximum durability.
The Audiophonics Pulsar cable is carefully assembled by hand in our workshops in France.
Technical specifications
Product typeUSB Cable
Connectors1x USB-A
1x USB-B
Length0.75m
External diameterØ9.5mm
Conductors4N OFC Copper
Conductors section4x 0.5mm²
Conductors insulationPTFE
ShieldingAluminium foil
Braided Copper
External sheathPE
Covering sheathBraided Nylon
Conductors platingSilver
Contacts materialCopper alloy
Contacts platingGold 24k
Length (m)0.7
ShieldingYes
Section (mm²)0.50
ConnectorUSB-A
ConnectorUSB-B
3 reviews
Moyen
J'ai ce câble depuis longtemps et je n'ai pas plus l'utiliser en raison du poids des connecteurs qui sont très lourds, beaucoup trop lourds. Ils viennent faire travailler dangeureusement les prises USB des machines sur lesquelles le câble est branché...
This review has been posted for AUDIOPHONICS PULSAR Male USB-A to Male USB-B Cable Silver / Gold Plated 0.75m
Pulsar hodně přesahuje svoji cenovou kategorii.
Srovnal Cardas za 20x větší cenu.
Très bon produit!
J'ai des modèles Neotech argent et cuivre en usb, permettant aussi de comparer avec ce Pulsar.
D'emblée, le Pulsar procure une restitution détaillée, avec de jolis timbres. Comparé au Neotech usb cuivre, c'est le même niveau de qualité pour ce qui est de la définition. Le Pulsar sans doute grâce à l'argent, procure cet aigu fin et capable de variété, sans que ce soit aussi marqué que sur le Neotech argent.
Sur mes appareils, le Pulsar a un équilibre plutôt rond, concernant le grave, le haut grave et le bas médium. Comparé au Neotech cuivre, le médium semble un peu en retrait mais il a une douceur de velours qui à mon avis est un des caractères du câble.
Attention ce qui est valable chez moi ne l'est pas forcément ailleurs!
Ce qui est certain, ce câble est de grande qualité pour un prix accessible, et peut être essayé à côté des meilleurs câbles usb.
Je le préfère sur mon installation casque, et réserve le Neotech cuivre sur ma chaîne avec enceintes car le résultat et l'équilibre sont les meilleurs que j'ai trouvés pour l'instant.
Sur casque, le Pulsar fonctionne très bien, je le préfère au Neotech usb silver. Ça joue sur peu, sans doute des goûts personnels plus que la qualité des câbles.
 (5)
The Audiophonics Pulsar USB cable, thanks to a precise and meticulous design, using high-end materials, ensures a stable and clean signal...
