AUDIOPHONICS PULSAR Male USB-A to Male USB-B Cable Silver / Gold Plated 1.5m
The Audiophonics Pulsar USB cable, thanks to a precise and meticulous design, using high-end materials, ensures a stable and clean signal transmission for high quality sound reproduction.
Reference : 14829
64,90 €tax incl.
54,08 € tax excl.
Audiophonics Pulsar
Audiophonics Pulsar Câble USB-A Mâle vers USB-B Mâle Plaqué Argent / Or 1m
The Pulsar integrates a cable whose conductors are made of Copper OFC 4N with silver plating, ensuring maximum electrical conductivity. These conductors are individually insulated by a PTFE sheath. A double shielding composed of a copper braid and an aluminium foil guarantees a high immunity to parasitic noise. The cotton filling provides excellent mechanical strength and damping.
Another specificity of this cable is that the DATA and 5V voltage wires are separated by a shield, in order to limit considerably the interferences between conductors. Finally, we cover the cable with a beautiful and effective Nylon braided sheath, which also contributes to the resistance of the cable to mechanical stress.
The connectors used are Viborg UA201 for USB-A and Viborg UB201 for USB-B. The latter, particularly robust, benefit from contacts made of a copper alloy with 24k gold plating, promoting both conductivity and oxidation resistance for maximum durability.
The Audiophonics Pulsar cable is carefully assembled by hand in our workshops in France.
Technical specifications
Product typeUSB Cable
Connectors1x USB-A
1x USB-B
Length1.5m
External diameterØ9.5mm
Conductors4N OFC Copper
Conductors section4x 0.5mm²
Conductors insulationPTFE
ShieldingAluminium foil
Braided Copper
External sheathPE
Covering sheathBraided Nylon
Conductors platingSilver
Contacts materialCopper alloy
Contacts platingGold 24k
Length (m)1.5
ShieldingYes
Section (mm²)0.50
ConnectorUSB-A
ConnectorUSB-B
2 reviews
Mon meilleur câble usb
J'ai eu des câbles de bases, des audioquest, un câble usb diy acheter sur leboncoin, mais celui la c'est le meilleur.
En terme de qualité audio c'est meilleur qu'un câble de base c'est sûre, et je n'entend pas de différence avec des câbles plus chère.
Et en plus de sa c'est un tank, une qualité de fabrication irréprochable a mes yeux.
This review has been posted for AUDIOPHONICS PULSAR Male USB-A to Male USB-B Cable Silver / Gold Plated 1.5m
100% satisfait !
Rapport qualité /prix exceptionnel !
J'avais besoin d'un câble de qualité pour relier mon MacBook au Dac Chord Qutest , ce câble usb monté par Audiophonics est une très bonne surprise !
Qualité des timbres, neutralité exemplaire, acoustique des lieux d'enregistrement, tout est là!
Que vive la musique !
Bravo, je recommande !
The Audiophonics Pulsar USB cable, thanks to a precise and meticulous design, using high-end materials, ensures a stable and clean signal...
