Cable Female USB-A 3.0 to Male USB-C OTG Copper White PVC sheath 20cm
This cable has a USB-A 3.0 Female connector and a USB-C (3.1) Male connector. It will allow you to connect peripherals or cables with a USB-A male connector to a device with a USB-C female connector. The USB standards of this cable (3.0 and 3.1) ensure optimal transfer speed, as well as the copper conductors ensure excellent signal conductivity.
Reference : 12951
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 22-04-2025.
USB-A 3.0 to USB-C Cable
Copper PVC Sheath White 20cm
Câble USB-A vers USB-C
Plus, you also get an advantage of the USB-C format, it's totally reversible. Thus, there is no need to worry about reversing the direction to connect it.
The cable is also OTG. As a result, two OTG devices connected together with this cable will be able to communicate and exchange data, without going through an intermediate computer. This makes it possible, for example, to connect an OTG-compatible USB stick or amplifier to your smartphone that is also compatible with this technology.
ConnectorsFemale USB-A 3.0
Male USB-C (3.1)
Cable length15cm
Total length20cm
Conductor materialCopper
Cable sheathPVC
Cable diameter3.9mm
OTGYes
ColorWhite
Length (m)0.2
ShieldingYes
Section (mm²)N/A
ConnectorUSB-C
ConnectorUSB-A
This cable has a USB-A 3.0 Female connector and a USB-C (3.1) Male connector. It will allow you to connect peripherals or cables with a USB-A male...
