Le câble USB 3.1 que l'on attendait, rapide, et du débit, enfin.
Male USB-C 3.1 to Male USB-C 3.1 Cable 5A Super Speed 10Gbps
This USB cable has a USB-C 3.1 connector on both sides and allows you to connect two devices with this connection, such as a smartphone and a recent laptop or tablet. The cable delivers 5A load and features SuperSpeed USB SS10 technology, offering transfer speeds up to 10 Gbps.
Fast charge
The cable can deliver up to 5A, allowing you to quickly charge devices like your smartphone, tablet or any other battery-powered device with a USB-C charging port.
USB 3.1 Gen 2
With this new USB 3.1 standard and USB SuperSpeed SS10 technology, the cable offers file transfer speeds up to 10 Gbps.
Reversible design
Type C connectors are reversible and therefore cannot be inserted in the wrong direction, greatly facilitating connection.
4K Resolution
If you have a monitor / screen with a USB-C connection and a 4K panel, this cable will allow you to send streams of this resolution for a detailed image.
Cable type | Male USB-C 3.1 to Male USB-C 3.1 |
Technology | SuperSpeed USB SS10 |
Max transfer speed | 10 Gbps |
Max current | 5A |
Length | 0.5m |
USB-IF Certification | Yes |
Cable section | 30AWG (0.0509mm²) |
Cable diameter | 5.2mm |
Color | Black |
Length (m) | 0.5 |
Shielding | NC |
Section (mm²) | 0.0509 |
Connector | USB-C |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
