The USB-C to Lightning DD MFi09S cable benefits from a perfectly mastered design, using very high quality components in order to offer excellent conductivity and therefore signal transmission. Thus, its conductors are made of pure silver Litz wire for the data part and OFC copper for the power supply.
Male USB-C Cable Silver / OFC Copper 50cm
The parallel structure of the cable benefits from a double shielding to protect the data and power sections independently. The signal is thus protected from interference and the transmission is perfectly stable.
Product type | USB-C / Lightning Cable |
Connectors | 1x Male USB-C 1x Male Lightning |
Length | 50cm |
Cable conductors material | Data: Pure silver Litz wire Power: OFC Copper Litz wire |
Cabe conductors section | Data: 0.109mm² (26.7AWG) Power: 0.141mm² (25.6AWG) |
Cable conductors shielding | Data: OFC Copper Litz wire + Silver plated LCOFC Litz wire Power: Silver plated LCOFC Litz wire |
Internal insulation | High precision chemical foam PE |
Outer insulation | Transparent PVC SoftFlex |
OTG | No |
Color | Gray / Silver |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
