This DD TC07BL USB cable is a high-quality USB-B to Lightning cable. Part of the Nyx version 2.0 series, it features silver shielding and double insulation in PE NUC and PVC for optimum conductivity and interference resistance. It features two conductors, a pure silver DATA conductor and a pure OFC copper charge conductor. The USB connectors on this cable use the USB 2.0 standard.
Product type | USB-B to Lightning cable |
Connectors | USB-B Lightning |
Length | 50cm |
Diameter | Ø4mm |
Data conductor material | Pure silver (Ø0.08mm×19×2) |
Data conductor cross-section | 2x 27AWG |
Power conductor material | OFC copper (Ø0.05mm×19×7×2) |
Power conductor cross-section | 2x 22.9AWG |
Insulation | Internal insulation: PE NUC External insulation: PVC |
Shielding | Silver-plated LCOFC copper Litz wires |
Connectors body material | Metal |
Package | 1x USB-B to Lightning TC07BL DD Hi-Fi cable |
Length (m) | 0.5 |
Shielding | Yes |
Section (mm²) | 0.102 |
Section (mm²) | 0.258 |
Connector | Lightning |
Connector | USB-B |
Conductors material (Cable) | Silver |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
