Male USB-A to Male USB-B Cable Silver / OFC Copper 50cm
The USB-A to USB-B DD TC09BA cable offers a very nice design quality, promoting an efficient signal transmission. It physically separates the data cable from the power supply cable to avoid any interference. The first one integrates silver Litz wire conductors, with a double shielding of OFC copper Litz wire and silver-plated LCOFC copper Litz wire. The second one uses OFC copper Litz wire conductors, with a silver plated Litz copper LCOFC wire shielding. The whole set benefits from a PE foam insulation and is covered by a flexible PVC outer jacket. Each connector is also gold plated, ensuring both a very good conductivity and resistance to oxidation.
Product type | USB Cable |
Connectors | 1x Male USB-A 1x Male USB-B |
Length | 50cm |
Conductors | Data cable : Silver Litz wire Power cable : OFC Copper Litz wire |
Conductors sections | Data cable : 2x 0.109mm² (26.7AWG) Power cable : 2x 0.141mm² (25.6AWG) |
Shielding | Data cable : OFC Copper Litz wire + Silver plated LCOFC Copper Litz wire Power cable : Silver plated LCOFC Copper Litz wire |
Insulation | Inner: PE foam Outer : SoftFlex PVC |
Length (m) | 0.5 |
Shielding | Yes |
Section (mm²) | 0.14 |
Section (mm²) | 0.109 |
Connector | USB-A |
Connector | USB-B |
Conductors material (Cable) | Silver |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
