The TC09L from ddHiFi is a USB-C to USB-C OTG cable with angled connectors. One of the connectors is gold-plated for flawless oxidation resistance, while the other is silver-plated for maximum conductivity. To ensure the best possible data transmission, the TC09L separates the power supply and data transfer into two separate cables. The power cable is made of OFC copper, while the data cable is made of pure silver. To ensure electromagnetic impermeability, each of these two cables is shielded by a silver-plated copper coating.
Product type | USB-C Cable |
Connectors | 2x Male USB-C |
Length | 8cm |
Cable conductors material | Data: Pure silver Litz wire Power: OFC Copper Litz wire |
Cabe conductors section | Data: 2x 0.109mm² (26.7AWG) Power: 2x 0.141mm² (25.6AWG) |
Cable conductors shielding | Data: OFC Copper Litz wire + Silver plated LCOFC Litz wire Power: Silver plated LCOFC Litz wire |
Internal insulation | Polyethylene foam (PE) |
Outer insulation | Transparent PVC SoftFlex |
OTG | Yes |
Weight | 12.2g |
Color | Silver Black |
Package | 1x DD TC09L |
Length (m) | 0.08 |
Shielding | Yes |
Section (mm²) | 0.14 |
Section (mm²) | 0.109 |
Connector | USB-C |
Conductors material (Cable) | Copper |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
