DDHifi TC07S USB-C Cable Pure Silver / OFC Copper OTG 50cm
The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to avoid interference. The data conductors are made of pure silver, while the power conductors are made of OFC copper, providing excellent conductivity.
Reference : 17806
44,90 €tax incl.
37,42 € tax excl.
Shipping date: 24-04-2025.
DD TC07S
Câble USB-C Argent Pur / Cuivre OFC OTG 50cm
DD TC07S Câble USB-C Argent Pur / Cuivre OFC OTG 50cm
The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to avoid interference. The data conductors are made of pure silver, while the power conductors are made of OFC copper, providing excellent conductivity. This USB-C cable also features dual PE NUC / PVC SoftFlex insulation.
The USB-C connectors do not incorporate a DAC.
DDHifi TC07S Câble USB-C Argent Pur / Cuivre OFC OTG 10cm
Product typeUSB-C cable
Connectors2* male USB-C OTG
Length50cm
DiameterØ4mm
Data conductors materialPure silver (Ø0.08*19*2)
Data conductors section2*0.102mm² (2*27AWG)
Power conductors materialOFC copper 0.05*19*7*2)
Power conductors section2*0.264mm² (2*22.9AWG)
InsulationInner insulation: PE NUC
Outer insulation: PVC SoftFlex
Shielding materialSilver plated LCOFC copper Litz wire
Connectors shell materialMetal
Weight20g
Package1* DD TC07S
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorUSB-C
Conductors material (Cable)Silver
2 reviews
Bon produit fonctionne sans problème
Fonctionne sans problème sur iPad Pro, associé au Chord Mojo2, et aussi au Earmen TR1.
This review has been posted for DDHifi TC07S USB-C Cable Pure Silver / OFC Copper OTG 50cm
Fait le job
Bon câble otg, bien fabriqué et esthétique.
Les connections sont franches et un petit clic pour les maintenir en place. Le signal est bien restitué sans trop monté dans les fréquences malgré l' argent.
Un peu cher peut être mais je recommande.
The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the...
