FIIO LD TC1 Male USB-C to Male USB-B Cable Copper Monocrystalline Dual Shielding Gold Plated 0.5m
With LD TC1, FIIO presents a USB-C to USB-B cable incorporating high-purity copper conductors for pure, stable signal transmission. Gold-plated connector contacts resist corrosion and oxidation. The LD TC1 is perfect for connecting a smartphone, tablet or computer with USB-C port to a DAC equipped with USB-B connectivity, such as the FIIO K5 Pro or FIIO K9 Pro, for example.
Reference : 18008
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 22-04-2025.
FIIO LD TC1
FIIO LD TC1 Câble USB-C Mâle vers USB-B Mâle Cuivre Monocristallin Connecteurs Plaqués Or Blindé 0.5m Noir
With LD TC1, FIIO presents a USB-C to USB-B cable incorporating high-purity copper conductors for pure, stable signal transmission. Gold-plated connector contacts resist corrosion and oxidation. This cable ensures interference-free data transmission and limits jitter. Multiple insulations cover the conductors to guarantee a high level of shielding. The cable is then covered with a PVC sheath and a second, braided, high-quality nylon sheath. The body of the connectors is made of an aluminum alloy for robustness and durability. The LD TC1 is perfect for connecting a smartphone, tablet or computer with USB-C port to a DAC equipped with USB-B connectivity, such as the FIIO K5 Pro or FIIO K9 Pro, for example.
The cable does not support devices requiring more than 200mA current and is not suitable for recharging the battery of connected devices.
Quality structure
FiiO's LD TC1 USB cable has a structure worthy of top-of-the-range cables, with copper conductors and a double shield consisting of aluminium foil and tinned copper braid.
Product typeUSB cable
Connectors1* Male USB-C
1* Male USB-B
Length0.5m
Cable conductors materialHigh-purity copper
Tinned copper
ShieldingAluminum foil
Braided tinned copper
Cable diameterØ5mm
SheathPVC
Braided nylon
Connectors body materialAluminum alloy
Connectors contacts materialCopper alloy
Connectors contacts platingGold
Max. Current200mA
ColorCable: Black
Connectors: Silver and black
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorUSB-B
ConnectorUSB-C
With LD TC1, FIIO presents a USB-C to USB-B cable incorporating high-purity copper...
