By buying this product you get 30 loyalty points
With the GT2 NCF, Furutech offers a USB-A to USB-B cable with a silver-plated OCC copper conductor and triple shielding. This cable also benefits from the NCF technology developed by Furutech, which coupled with the materials used and the meticulous design it has undergone, makes it an exceptional cable.
At the heart of the GT2 NCF is an NCF connector sleeve. With a hybrid multi-material construction, this innovative sleeve exploits a special crystalline NCF (Nano Crystal² Formula) material from Furutech with two ‘active’ properties: firstly, it eliminates static electricity by generating negative ions, and secondly, it converts thermal energy into far infrared. Furutech enhances this material with nanometric ceramic particles and carbon powder, taking advantage of their piezoelectric damping properties.
Precision engineered, the GT2 NCF features silver-plated OCC α (Alpha) copper conductors and high-density polyethylene insulation for optimum signal transmission. Its triple shielding and 24K gold-plated USB 2.0 connectors minimise electromagnetic interference and offer foolproof protection against oxidation.
The conductors that make up the GT2 NCF cable benefit from a two-stage Alpha cryogenics and demagnetisation process. Firstly, the conductors undergo deep cryogenic freezing using top-of-the-range refrigerants such as liquid nitrogen or helium. Once temperatures of between -196 and -250C° are reached, the conductors are subjected to internal stress, forcing the molecules that make them up into tighter bonds, resulting in a more stable overall structure and improved conductivity. In a second stage, the conductors are exposed to a ring demagnetisation treatment patented by the brand.
Product type | USB-B to USB-A cable |
Connectors | USB-B USB-A |
Length | 2.5m |
Diameter | Ø6.4mm |
Conductor material | Silver-plated OCC copper |
Connector plating material | 24k Gold |
Insulation | High density polyethylene |
Shielding | Aluminised mylar foil Al Mylar Braided conductor treated α (Alpha) |
Color | Purple |
Package | 1x FURUTECH GT2 NCF |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Conductors material (Cable) |
Conductors Plating (Cable) |
