RAS, c'est un câble qui câble bien.
Gold Plated USB-C to Micro USB Cable 20cm
As USB-C ports become more and more common, especially on smartphones and computers, this type of USB-C to Micro USB cable becomes an essential element. It will allow you to perform file transfers and/or reload your devices simply. With tinned copper conductors and gold plated contacts, as well as double shielding, this cable ensures excellent signal transmission and very good durability. The cable is OTG and therefore allows you to connect devices compatible with this technology (such as two OTG-compatible smartphones for file transfer, for example).
The OTG function of the cable works only if you use the UBC-C side in Host mode, not the Micro-USB.
Product type | USB-C / Micro USB Cable |
Compatibility | OTG |
Length | 20cm |
Contacts plating | Gold |
Shielding | Aluminium foil + Braided Nylon |
Sheath | PVC |
Max current | 2A |
Cable diameter | 3mm |
Color | Black |
Length (m) | 0.2 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | Micro USB |
Connector | USB-C |
Conductors material (Cable) | Copper |
Average votes 3.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cédric A.
Patrice N.
