By buying this product you get 45 loyalty points
2x USB-A (Audio + Power) to 1x USB-B 3.0 Cable 0.7m
Standard USB cables include both the power cable and the section carrying the data. A method absolutely avoid HiFi, it obviously affecting the quality of the restored signal, especially if each part is insufficiently isolated from others.
The Gemini3.0 completely corrects this problem.
Like its predecessor, the Gemini3.0 transports audio and power via two separate cables to isolate the different signals and not degrade them.
The cable incorporates OFHC copper conductors to maximize transfer quality. In addition, it benefits from high quality manufacturing with parallel low inductance mounting and quadruple shielding to protect the signal from RFI and EMI noise and thus ensure the highest quality transmission.
In a classic cable, the power and audio signals are confined in a single shield, insufficient to protect each signal from interference.
In the Gemini 3.0 USB cable, the audio and power signals are individually transferred thanks to a suitable shielding that minimizes interference.
With its machined connectors and RF3 filter design, Ifi Audio announces a new reference for the USB Audio cable.
Unlike its predecessor, the Gemini3.0 incorporates USB 3.0 connectors to ensure a much higher transfer speed. This new standard allows the audio signal to pass without disruption and gain quality.
Like the original Gemini, the Gemini3.0 power cable incorporates a larger cable section. In addition, its separate double-connector design ensures maximum conductivity and maximum signal quality.
The cable is not the only point of passage of the signal, Ifi Audio integrates to its product connectors of high quality. Thus, they also have an RF shield, machined in aeronautical grade aluminum. In addition, the contact is Gold plated, ensuring both excellent conductivity and durability.
The Gemini3.0 incorporates a custom-made three-way RF metal-based RF noise attenuation system. Each has a different effect range to expand attenuated RF noise. More than that, the central system is adjustable and can be moved along the entire length of the cable to cancel the antenna effect of the cable, according to its integration. The other two noise attenuation systems shall be kept as close as possible to the ends of the cable.
The Gemini3.0 combines perfectly with the iGalvanic3.0 and Micro and Nano USB 3.0 series products from Ifi Audio.
Thus, Galvanic 3.0 provides total galvanic isolation of USB3.0 / 2.0 signal and power supply.
The Micro / Nano USB3.0 ships a super regulator, ensuring very low noise (0.1uV / 0.5uV) and very low output impedance (around 0.00015 Ohm @ 1kHz and 0.00003 Ohm @ 100Hz DC) to maximize an impeccable USB connection.
USB Data | |
Construction | Minimum inductance parallel construction |
Conductors | 24 and 28AWG |
Conductor materiel | Heavy OFHC continuous cast copper silver matrix |
Insulation | HD Polyethylene |
Shielding | Quadruple-Shields |
Impedance | 90 Ohms |
Connectors | Ifi 'FINAL' USB |
Insulation resistance | 100 MOhm |
Tensile strength | 1500PSI |
USB power | |
Conductors | 12 AWG |
Conductor material | Heavy OFHC continuous cast copper |
Insulation | Linear Polyethylene (LPE) |
Current rating | 30A |
Length | 0.7m |
Weigth | 150g |
Length (m) | 0.7 |
Shielding | Yes |
Section (mm²) | 0.0810 |
Section (mm²) | 0.205 |
Connector | USB-A |
Connector | USB-B |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
