IFI AUDIO MERCURY 3.0 USB 3.0 Cable Isolated Power / Audio Quad Shields RFI Filter 0.5m
Unlike standard USB cables, the Mercury3.0 has the feature of a quad shield, allowing it both to enjoy protection against EMI / RFI interference but above all to completely separate audio and power signals.
By buying this product you get 20 loyalty points
Reference : 12717
209,00 €tax incl.
174,17 € tax excl.
Ifi Audio Mercury3.0
USB-A / USB-B 3.0 Cable Quad Shielding Power / Audio Isolated
Ifi Audio Mercury3.0 Câble USB 3.0
shield et usb 3.0
Quadruple shields and USB 3.0
Mercury3.0 also incorporates a triple RF noise attenuation system based on custom metal oxide ceramic. Each has a different effect range to widen attenuated RF noise. More than that, the central system is adjustable and can be moved over the entire length of the cable to cancel the antenna effect of the cable, depending on its integration. The other two noise attenuation systems must be kept as close as possible to the ends of the cable.
RF3
RF3 Strength
Connecteurs haute qualité ifi audio mercury3.0
High quality throughout the linee
EFinally, the cable connectors have been specially designed to provide the cable with end-to-end RF shielding. With an aluminum body and gold plated contacts, this cable offers great durability.
Length0.5m
Connectors typeMale USB-A 3.0 to Male USB-B 3.0
ConstructionMinimal inductance parallel construction
Conductors section24 AWG (0.205mm²) / 28 AWG (0.0810mm²)
Conductors materialHeavy OFHC continuous cast copper silver matrix
InsulationHD Polyethylene
ShieldingQuadruple shields
Impedance90Ω
Insulation resistance100 MΩ
Tensile strength1500PSI
Weight98g
Length (m)0.5
ShieldingYes
Section (mm²)0.205
Section (mm²)0.0810
ConnectorUSB-B
ConnectorUSB-A
Unlike standard USB cables, the Mercury3.0 has the feature of a quad shield, allowing it both to enjoy protection against EMI / RFI interference...
